SRP527w VPN setup
Jul 18th, 2010
I need to know how to configure SRP527w  without a static outside  ip address to establish a VPN tunnel with VPNC3000.
Overall Rating: 5 (1 ratings)
Ganesh Hariharan Mon, 07/19/2010 - 01:47
To establish a VPN connection over the internet you need to have static public ip peering in configuration between the two devices.
Hope to help !!
Ganesh.H
toddz1234 Wed, 08/04/2010 - 18:19
Was hoping to be able to do Remote VPN. is there anyway to accomplish that?
Andrew Hickman Mon, 08/23/2010 - 02:51
Hi Sean,
We do not currently support VPN client on the SRP500 - point to point IPSec only at this time.
Andy
mattykoch Wed, 08/24/2011 - 22:53
Is there any update on the 527W supporting VPN endpoints or been a vpn server?
I would like to connect my iphone/ipad to the 527w via vpn, is this possible?
Cheers
Matt
superfoofoo Mon, 12/19/2011 - 02:39
Cheers
Matt
Yes, I was also wondering this. Is is possible with the right firmware to setup the SRP527W as a VPN server?
Andrew Hickman Mon, 12/19/2011 - 16:55
Hi All,
Our plan is to provide this in the next maintenance firmware release - this is expected early in Feb 2012.
Andy
mattykoch Sun, 02/05/2012 - 15:13
Hi Andy,
Any update on when the latest firmware will be available with the VPN feature??
Cheers,
Matt.
Andrew Hickman Sun, 02/05/2012 - 20:32
Hi Matt,
We're just starting some pre-release testing on this feature for the SRP527W - unfortunately we're running a little late on our earlier schedule.  Currently, we expect to post this towards the end of the month.
We have just released this feature for the SRP520W-U and SRP540W products.
Andy
icemanmelb Sat, 03/10/2012 - 15:51
Hi Andrew,
what is the update for vpn end point on the SRP 527W? It's now march 2012...
regards
icemanmelb Sun, 03/11/2012 - 01:48
Thanks for that Andrew,
I've just updated the firmware and discovered that site to site VPN no longer works as per your reply. So does that mean I can't have Site To Site VPN and Remote VPN to VPN end point running at the same time?
If so this is really a horrible design flaw on Cisco's part. Most users would like this router to be an End Point + Site To Site simultaneously.
regards
Paul
icemanmelb Sun, 03/11/2012 - 01:58
Hi Andrew,
Does that mean I have to reconfigure my router again for Site To Site for this new firmware?
regards
Paul
Andrew Hickman Mon, 03/12/2012 - 03:51
Hi Paul,
You shouldn't need to reconfigure your VPN settings for new firmware. It is only possible to use either the VPN remote access server, or site to site VPN functionality.  I appreciate that this limiting.
Andy
andreadente83 Fri, 08/02/2013 - 21:49
Hi Andrew,
i'm trying to set up my iphone and ipad and imac to connect to the router trough vpn,
i've set up the router but i can't find anywhere how to set the secret or certificate for it.
what is it used as certificate?
Andrea
Andrew Hickman Sun, 03/11/2012 - 01:10
The latest code posted on cisco.com includes VPN server.
Please note that this may be used as an alternative to site to site VPN ie when you enable the server, site to site is disabled.
Also, as it was referred to earlier in the thread, the SRP cannot be used as a VPN client.
Andy
sean-fatourchi Sun, 03/11/2012 - 09:47
If  I may,
I love cisco products but this one from the start has had so many bugs that they should be called Beetles.
just the fact that you can longin to the system as a user and see your VPN shared key in "clear text" is beyond comprehension.The device so fueature rich but poorly put together, why does it not support "Remote Vpn" is mind boggling. I certainly hope the issues has been addressed in the replacement product. Cant wait to get one to test.
Best,
Sean
sean-fatourchi Thu, 03/22/2012 - 17:06
Sorry folks, don't know where else to turn for help.
Just received the new SRP537w-u. After initial configuration with no issues, now when I click on the "Network" Tab to change the user password I see Wan setup / Web access page.
When I click on "VPN" tab I get Nat Traversal page. What is going on here?
Cisco, is this not supposed to be better than the old devise.
Common………
S
Andrew Hickman Fri, 03/23/2012 - 08:05
Hi Sean,
I believe that you are seeing an issue caused by some changes in Firefox versions 9 or 10.  We have a fix for this ready in our next maintenance release, but in the meantime, you should find that using a different browser will provide the right experience.
Andy
icemanmelb Fri, 03/23/2012 - 14:00
Thanks andrew,
I've actaully tried all 3 different browsers without success. still after updating the firmware, the site to site vpn button is no longer working. Perhaps there's a new way of configuring this setup now? If so, there's just no other documentation on it.
Just out of curiousity, why is it so hard for a vpn router to have site to site vpn and end user vpn simultaneously?
iandaniel Thu, 05/31/2012 - 18:00
I loaded the latest firmware onto my SRP527W and setup a VPN Group plus a user. Configured my iPad and it all connects fine so with the latest firmware you have the ability to support up to 5 IPSEC vpn clients it seems. I have an iPhone and iPad both working via VPN right now for email, web and internal network access.
Hope this helps,
--Ian
mattykoch Thu, 08/16/2012 - 14:38
I have just tried to config the VPN Server on the SRP527w and when I enter the details onto my idevice it prompts for a shared secret question.  It won't let me proceed without entering some details.  Then when I enter details it states not correct.
I have searched the admin guide for the srp527w though had no luck.
Any assisitance on what this paramter is and where you configure it?
Cheers
iandaniel Thu, 08/16/2012 - 15:04
Login to the router as admin
Go to the VPN tab
Expand cisco VPN on the left hand side
Select Group
Set a group name and a password for that group.
That should do it.
My firmware version is:
Firmware Version:1.01.27 (007) Jun 15 2012
Hope this helps.
--Ian
mattykoch Thu, 08/30/2012 - 00:51
Hi Ian,
I appreciate any assistance you can offer.  I am trying to connect a VPN from my iPa however I keep getting the error on the iPad "The VPN Server did not respond".  I can ping my router successfully and I also have the same (latest) firmware version as you.
Do you mind detailing the specifi settings yu cofigured on the SRP527w and are you using the an inbuilt IOS Ciisco VPN client or a third party app on the iPad?
I appreicate any assistinace you can offer.
Matt
Andrew Hickman Thu, 08/30/2012 - 00:58
Hi Matt,
You should just be able to use the iPad built in IPSec client.
SRP configuration just requires you to enable the VPN server, configure group name/secret and usernames and passwords for each user.
Don't configure the iPad VPN to use certificates.
Andy
mattykoch Thu, 08/30/2012 - 03:04
it is now working - thanks heaps guys.
When I configure the ip address for the vpn group, I can't choose the same subnet range as my primary vlan.
is the general rule to create another vlan/subnet and then enable inter vlan routing??
iandaniel Thu, 08/30/2012 - 02:05
Hi Matt,
I use the following. I've added comments where I can to try and help.
iPad
Router Settings
--Ian
superfoofoo Thu, 08/30/2012 - 01:27
On a side note, can someone tell me how I can connect to my SRP527W with my Windows laptop? I can connect to it with my iPhone and iPad but I can't figure what settings to use in the Windows 7 VPN config to get to work. Cheers.
iandaniel Thu, 08/30/2012 - 02:16
I think you'd need the cisco VPN client to be installed for that, or maybe a 3rd party one that supports cisco VPN, I think at least one of them does. Personally I'd use the cisco client if I had the choice and was using Windows.
--Ian
superfoofoo Thu, 08/30/2012 - 02:47
--Ian
Do you know where you can get the Cisco VPN client from (for Windows 7)? I thought Cisco would have it available for download on their website, but I should have known better that Cisco don't give away anything for free.
iandaniel Thu, 08/30/2012 - 02:54
You have to purchase the cisco client for Windows so there shouldn't be any place you can just download it. Maybe one of the 3rd party ones will do the job for you? I think shrewsoft has basic cisco VPN support in their client for Windows but I have no idea how reliable it is.
--Ian
superfoofoo Thu, 08/30/2012 - 03:03
Hi Ian.
Thanks for pointing me to the shrewsoft client. I've downloaded their client and will give it a go although their last stable release was in 2010!
You would think if you buy a router with a VPN server that you would get the VPN client with it. Another reason Cisco annoys me. I bet to buy the Cisco VPN client from Cisco would cost more that what I paid for the router.
If the shrewsoft client is no good, I'll go back to using a OpenVPN server running in a virtual machine on my home server to connect into my network. Convoluted I know, and something I was trying to avoid by buying a router with a built in VPN server but Cisco may give me no choice with their overpriced services for SOHO users.
iandaniel Thu, 08/30/2012 - 03:40
I think all you need is a support contract to get the cisco VPN. I don't know how much that is for the SRP527 though or if that would entitle you to it. Maybe give cisco a call and see what they say.
With regard to the VPN support, when the router first came out it didn't have it so maybe that's why they don't have anything like that on offer for this router. It works with the following that I know of without additional software being needed:
Macs
iPads
iPhones
Android devices (latest ones anyway from what I've heard, I haven't tried this one)
So for a lot of people it's still a nice bit of functionality cisco added to the router.
--Ian
Related Content
