SSL AO critical error message
Jul 18th, 2010
Hi Zach
I found a critical error message in branch WAE, NME-WAE-502-K9
/* Style Definitions */ table.MsoNormalTable {mso-style-name:表格內文; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; mso-bidi-font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:新細明體; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-font-kerning:1.0pt;}
SSL AO: Connection with Dataserver is broken. Please restart SSL AO
and I restart the SSL AO, but it still shows again
SSL AO configuration is default in my WAE, is Pass-Through
have you ever seen this message ?
Zach Seils Mon, 07/19/2010 - 17:21
What version of WAAS are you running?  Did you recently upgrade?  If so, from what version?
kanechang Mon, 07/19/2010 - 20:23
the default IOS is 4.1.3b and upgrade to 4.1.5f
it runs about a month
I restart SSL service again last night and now is ok
