ACS notice password is expiring
Jul 19th, 2010
I used ACS4.1 and MS-AD 2003 for external database. I need windows dialog box to notify me about password is expiring such as "14 days password expired need to change". Can ACS do this task? if can, how can i configure?
Remark: I used wireless PEAP, EAP-MSCHAPv2 for authentication protocol. My Laptop use XP.
Thanks.
Overall Rating: 5 (1 ratings)
Ganesh Hariharan Mon, 07/19/2010 - 01:43
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Thanks.
Check out the below link for Password expiring method in ACS
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.1/user/GrpMgt.html#wp525115
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
HELPDESK THAILAND Mon, 07/19/2010 - 02:20
Hi Ganesh.H,
Thank you for your advice, however, i have question to ask you about this:
- Due to i used external database, AD 2003, if i setup password aging such as active period, warning period or whatever on ACS. Will ACS sync date/time all user's password with AD?
Thanks.
Ganesh Hariharan Mon, 07/19/2010 - 02:40
Hi Ganesh.H,
Thanks.
Check out the below link Password Aging for Users in Windows Databases
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.2/user/guide/GrpMgt.html#wp479732
Hope to Help !!
Ganesh.H
