Can't see result after a data collection in CM
Jul 19th, 2010
Hi all,
I have a problem with the Campus Manager (version 4.1.0). After a data collection i try to se the result but get the following error:
Report could not be found. I have tried to restart the ANI server, but same result. I have also tried to reinit the CM database, but same result. I still get the error: Report could not be found.
Please help
Thanks in advance.
Rgds,
Jesper
Joe Clarke Mon, 07/19/2010 - 12:26
There is no Campus 4.1.0.  Do you mean 5.1.0?  Exactly what report are you trying to run?
jesper_fr Mon, 07/19/2010 - 23:21
Hi Joseph,
The campus version is 5.0.6.
It's the result of the data collection I want to see. At the attached screenshot of the CM, at the link where it says 115 devices. If I try to see the devices that it has done the data collection from I get the error " report could not be found"
Rgds,
Jesper
Joe Clarke Tue, 07/20/2010 - 10:16
You have Campus 4.0 which is no longer supported.  I recommend you upgrade to LMS 2.6 SP1 then go to Campus 4.0.13.  If the problem persists then, post the ani.log and the Campus.log.
Joe Clarke Wed, 07/21/2010 - 20:48
Your Campus Manager screenshot said 4.0.0.  It should say 5.0.6.  Post the Campus.log and ani.log.
jesper_fr Sun, 07/25/2010 - 23:03
I cannot open a TAC request as I can't find the product under my contract.
