L2 redirection between a 3750 and WAE 674 WCCP
Jul 19th, 2010
hi
we are using a WAE 674 on a cisco 3750 in WCCP
WCCP is configured to use L2 redirection
but we saw this on the switch
Global WCCP information:
    Router information:
        Router Identifier:                   192.168.100.1
        Protocol Version:                    2.0
    Service Identifier: 61
        Number of Service Group Clients:     1
        Number of Service Group Routers:     1
        Total Packets s/w Redirected:        1
          Process:                           0
          CEF:                               1
        Redirect access-list:                -none-
        Total Packets Denied Redirect:       0
        Total Packets Unassigned:            0
        Group access-list:                   -none-
        Total Messages Denied to Group:      0
        Total Authentication failures:       0
        Total Bypassed Packets Received:     0
    Service Identifier: 62
        Total Packets s/w Redirected:        11
          Process:                           0
          CEF:                               11
switch configuration
vlan 1 and 2 : data
vlan 3 routeurs
vlan 4 : WAE
interface Vlan1
ip address 10.0.0.1 255.255.0.0
ip wccp 61 redirect in
standby 0 preempt
standby 1 ip 10.0.0.6
standby 1 priority 150
standby 1 preempt
standby 1 name hsrp_vlan_1
interface Vlan2
ip address 10.1.0.1 255.255.0.0
standby 2 ip 10.1.0.6
standby 2 priority 150
standby 2 preempt
standby 2 name hsrp_vlan_2
interface Vlan3
description Routage-FT
ip address 192.168.1.4 255.255.255.0
ip wccp 62 redirect in
standby 3 ip 192.168.1.6
standby 3 priority 150
standby 3 preempt
standby 3 name hsrp_vlan_3
interface Vlan4
description VLAN WCCP
ip address 192.168.100.1 255.255.255.0
WAE configuration
wccp router-list 8 192.168.100.1
wccp tcp-promiscuous mask src-ip-mask 0x1741 dst-ip-mask 0x0
wccp tcp-promiscuous router-list-num 8 l2-redirect mask-assign l2-return
wccp version 2
Michael Korenbaum Mon, 07/19/2010 - 05:57
  • Bronze, 100 points or more
This counter on the 3750 is a software counter, but all WCCP redirection should be happening in hardware.  Thus, it is expected the number of redirected packets to be zero or very low.  The proper way to tell if WCCP is redirecting traffic to your WAE is to issue the command "show wccp gre" on the WAE and look for the line "transparent non-GRE packets received."
Example:
pdi-7341-19#sh wccp gre
Transparent GRE packets received:              0
Transparent non-GRE packets received:          28887345
Transparent non-GRE non-WCCP packets received: 0
Total packets accepted:                        26012975
Invalid packets received:                      0
Packets received with invalid service:         0
Packets received on a disabled service:        0
Packets received too small:                    0
Packets dropped due to zero TTL:               0
----output omitted ------
Cheers,
Mike Korenbaum
Cisco WAAS PDI Help Desk
http://www.cisco.com/go/pdihelpdesk
wrobbin Thu, 07/22/2010 - 05:37
hostname#sh ip wccp (61 or 62) detail
WCCP Client information:
        WCCP Client ID:          x.x.x.x
        State:                   Usable
        Redirection:             GRE
        Packet Return:           GRE
        Assignment:              HASH
        Initial Hash Info:       00000000000000000000000000000000
        Assigned Hash Info:      FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
        Hash Allotment:          256 (100.00%)
        Packets s/w Redirected:  513071848
        Connect Time:            9w6d
        Bypassed Packets
          Process:               0
          CEF:                   2
          Errors:                0
hostname#
