Multi Domain SSL certificates on ACE
dario.didio
Level 4
Level 4
I would like to know if the ACE supports multi domain SSL certificates.
I have a VIP with multiple websites behind with different domains (www.abc.com, www.def.com...), so a wildcard certificate is not usable for me.
After some research I found Multi Domain certificates which could solve my problem of multiple domains behind a single VIP for SSL offload.
I assume these are certificates like any other certificates and the ACE wouldn't have a problem with them, but would just like to ask if someone has experience with this.
Thanks in advance.
Br,
Dario
litrenta
Level 3
Level 3
Hi Dario
yes ace does support these. multi domain certificates also called UCC certs will contain multiple alternate subject names int the cert. see:
http://help.godaddy.com/article/3908
Ace is agnostic to these and will serve the cert up to the client.
