07-19-2010 04:07 AM - edited 03-04-2019 09:06 AM
Dear sir,
I have two cisco 4510 E switches now i want to use these two switches in ACTIVE_ACTIVE or ACTIVE-STANDBY mode .Is there any config examples to achive this.
srini
07-19-2010 12:34 PM
2 separate chassis will work independently.
If you want to have 2 switches acting as one logical switch (similar to an ACTIVE<->ACTIVE setup), the option is not present in the 4500 line.
Edison.
07-19-2010 09:38 PM
Edison,
Thanks for ur reply and can i get indipendent config examples.
Thanks for ur valuble answer
srini
07-20-2010 05:18 AM
There isn't any cookie cutter config for switches, you need to understand what are you doing and what services/features to enabled and disabled.
Best to become familiar with the documentation: http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/54sg/configuration/guide/config.html
It's all in there.
Edison
