NAC HA deployed over WAN
Jul 19th, 2010
Hi ,
Can CAM/CAS be deployed in HA over WAN?. CAM1/CAS1 in DC1 and CAM2/CAS2 in DC2.
Thanks all
Faisal Sehbai Mon, 07/19/2010 - 06:33
Not supported. To make this work in any case you're looking at extending L2 VLANs across your WAN with LAN-like latencies. If you can manage that, then it might work, but in current versions geographically dispersed HA setups aren't supported.
victor.alazaroae Mon, 07/19/2010 - 07:04
Hi Faisal,
This is what i'm thinking , extending L2 VLANs across WAN with LAN-like latency. But i want to know what are these values (delay, bandwith) between sites so i don't have problems with the HA?. The customer wants to implement HA with one server in one DC and one server in DC(the solution involves NAM HA , NAS HA and Profiler HA) with L2 connection between them over WAN.
Faisal Sehbai Mon, 07/19/2010 - 23:58
Latency should be less than 200 msec and ample bandwidth so the CAM can do it's heartbeat and synchronization of it's databases.
