UCM 7 and CME - no "Display" info in called number
Answered Question
Hi! I have a h323-trunk between UCM 7 and CME. In CME I have a ephone-dn 100 with label "TEST". On UCM I have phone with line 200 - Display (Internal Caller ID), Alerting name "CENTER". When I call from UCM to CME phones, I can see dialed number 100 and label TEST on my phone. But on CME phone I can only see calling number 200 without any info from Display or Alerting. How can I fix it to transfer Display and Alerting name label to CME phones?
Correct Answer by Adrian Saavedra about 6 years 6 months ago
In the gateway configuration in CM, make sure the the Display IE Delivery is checked for call routing information - outbound calls.
Hope it helps, please rate if it helps.
Kind regards,
- Adrian.
Overall Rating: 3 (2 ratings)
iantra123 Mon, 07/19/2010 - 06:57
The problem is in the CUCME.
Have you verified the extension Name ?
Make sure on the label, description, and NAME
Correct Answer
Adrian Saavedra Mon, 07/19/2010 - 08:03
Kind regards,
- Adrian.
I don't have problem with "Name" and "Label" configured on CME. I can see all of it on UCM phone when make a call from CME to UCM phone or call from UCM to CME. But I don't see on CME phone "Display ID" or "Alerting name" configured on UCM phone line when I make a call from UCM to CME.
Call: CME --> UCM  -- on UCM phone I see "TEST (100)", on CME phone I see only "200"
Call: UCM --> CME  -- on UCM phone I see "TEST (100)", on CME phone I see only "200"
