Duplex problem with inline card WAN0
Jan Rockstedt
We have problem with our newer WAE 574 with version 4.1.7 and inline card for the WAN port.
We have an Cisco router on the WAN and have tried with configure100/full and auto/auto, crossover cable and staight-through, but the WAE WAN0 is olny going up in 100/half.
If we change the WAE inlinegroup from auto/auto in to 100/full, the router and WAE WAN0 interface goes down.
On the LAN side we use staight-through cable and the switch port is in fixed 100/full without any problem, see below
#sh run
interface InlineGroup 1/0
inline vlan all
#sh interface inlineport 1/0/wan
Device name        : eth4. Bypass master interface.
Packets Received   : 313723
Packets Intercepted: 308703
Packets Bridged    : 5777
Packets Forwarded  : 244732
Packets Dropped    : 0
Packets Received on native      : 0
Active flows for this interface : 0
Ethernet Driver Status
Type:Ethernet
Ethernet address:00:E0:ED:0E:43:46
Maximum Transfer Unit Size:1500
Metric:1
Packets Received: 313615
Input Errors: 0
Input Packets Dropped: 0
Input Packets Overruns: 0
Input Packets Frames: 0
Packet Sent: 274786
Output Errors: 698
Output Packets Dropped: 0
Output Packets Overruns: 0
Output Packets Carrier: 698
Output Queue Length:100
Collisions: 1152
Base address:0x5000
Flags:UP BROADCAST RUNNING MULTICAST
Link State: Interface is up,line protocol up
Mode: autoselect, half-duplex, 100baseTX
#sh interface inlineport 1/0/lan
Device name        : eth5. Bypass slave interface.
Packets Received   : 298785
Packets Intercepted: 273891
Packets Bridged    : 30463
Packets Forwarded  : 369929
Packets Dropped    : 0
Type:Ethernet
Ethernet address:00:E0:ED:0E:43:47
Metric:1
Packets Received: 298775
Input Errors: 0
Packet Sent: 375792
Output Errors: 0
Output Packets Carrier: 0
Collisions: 0
Base address:0x5020
Mode: autoselect, full-duplex, 100baseTX
Any sugestion for our problem?
Jan
gustavosmivel
I've configured the inline cards as per below and no problem observed on same scenario.
inline vlan all
failover timeout 3
no autosense
bandwidth 100
full-duplex
exit
interface InlineGroup 1/1
inline vlan all
failover timeout 3
no autosense
bandwidth 100
full-duplex
exit
Yes it shoulden't be any problem as I have already seven 574 up and running.
But the three new last one there is an problem with.
The only thing i have done is to upgrade my CMA to 4.2.1
Could this be an issue?
Jan
Zach Seils
Level 7
Level 7
Can you provide the configuration and show interface output from the router as well?
Zach
Hi Zach,
We change the cable between the router and the WAE to straight-throu and change the router interface to autosense.
This solved the problem.
Now we have two more 574 to go. ;-)
For us that have 512, 612, 274, 574 and 674 up and running, the 574 is hard sometimes to get up in right speed and duplex.
Thx Jan
