How to configure WLC to work with ACS5.0
Jul 19th, 2010
I have wireless users and needs to authenticate using ACS5.0. Please how can i configure WLC and ACS5.0.
thank you and best regards
Edwin
jrabinow Tue, 07/20/2010 - 08:54
I think it will be best if you do this with ACS 5.1 . ACS 5.1 supports custom attributes/services with TACACS+
Eric Hansen Tue, 07/20/2010 - 09:08
Where are your users stored?  In ACS or in some other system like MS Active Directory?
**edit
Assuming you are talking to AD and you worked out your certs and all that junk with AD, one thing I saw with the WLC controllers specifically with the ones that go into the 6500's is they talk to ACS on multiple IP's.  I had to setup the  Network Devices on the ACS for both the management IP of the WLC and the control IP in the specific VLANs wireless clients were going to be depostied in.  *see attached*  It took a call to tac to find it and in their words "oh thats kinda odd".  hth
e-
