WAAS 7341 LOG
Jul 19th, 2010
Can we have a sh log with all logs on WAAS 7341 because my "sh log"
is showwing the below only.
USSMCWAGDRH001#    sh log
Syslog to host is disabled.
Syslog to console is enabled
Priority for console logging is set to:  warning
Syslog to disk is enabled
Priority for disk logging is set to:  notice
Filename for disk logging is set to:  /local1/syslog.txt
Syslog facility is set to *
Syslog disk file recycle size is set to 10000000
USSMCWAGDRH001#
Michael Korenbaum Mon, 07/19/2010 - 08:06
  • Bronze, 100 points or more
The show log command only shows you how logging is configured on the WAE.  If you want to view the contents of any file on the WAE use the type-tail command or the less command.
For example to view the last 50 lines of the syslog.txt file use the command "type-tail syslog.txt 50"
Cheers,
Mike Korenbaum
Cisco WAAS PDI Help Desk
http://www.cisco.com/go/pdihelpdesk
