High CPU utilisation on 6509 switch
Jul 19th, 2010
My Cisco 6509 switch 100% utilisation for more than 3 hrs now. When I used the command "show process cpu" i got the below output,
16407    97.2%   95.9%    96.0% ios-base
Can you please let me know why the CPU threshold is very high ?
Thanks & Regards
Murali
burleyman Mon, 07/19/2010 - 08:11
  • Blue, 1500 points or more
Can you run the following command and post the output.
Show tcp brief
Mike
Muralikrishnan_P Mon, 07/19/2010 - 08:45
Please find the output of "show tcp brief"
TCB Local Address Foreign Address (state)
010A0110 10.24.8.2:22 10.24.19.251:4219 ESTAB
Murali
burleyman Mon, 07/19/2010 - 09:37
Run this command and see if the CPU goes back to normal.
clear tcp tcb 010A0110
Do not telnet into the switch after you run this command. Only go in through the Console port itself.
Muralikrishnan_P Mon, 07/19/2010 - 09:51
I tried this command but no luck,
CPU utilization for five seconds: 100%; one minute: 100%; five minutes: 100%
PID 5Sec 1Min 5Min Process
1 0.1% 0.4% 0.8% kernel
3 0.0% 0.0% 0.0% devc-pty
4 0.0% 0.0% 0.0% devc-mistral.proc
5 0.0% 0.0% 0.0% pipe
4102 0.0% 0.0% 0.0% dumper.proc
4103 0.0% 0.0% 0.0% pcmcia_driver.proc
4104 0.0% 0.0% 0.0% bflash_driver.proc
12297 0.0% 0.0% 0.0% mqueue
12298 0.0% 0.0% 0.0% flashfs_hes.proc
12299 0.0% 0.0% 0.0% dfs_bootdisk.proc
12300 0.0% 0.0% 0.0% ldcache.proc
12301 0.0% 0.0% 0.0% watchdog.proc
12302 0.0% 0.0% 0.0% syslogd.proc
12303 0.0% 0.0% 0.0% name_svr.proc
12304 0.0% 0.0% 0.0% wdsysmon.proc
12305 0.0% 0.0% 0.0% sysmgr.proc
16386 0.0% 0.0% 0.0% chkptd.proc
16402 0.0% 0.0% 0.0% sysmgr.proc
16403 0.0% 0.0% 0.0% syslog_dev.proc
16404 0.0% 0.0% 0.0% itrace_exec.proc
16405 0.0% 0.0% 0.0% packet.proc
16406 0.0% 0.0% 0.0% installer.proc
16407 97.9% 97.5% 97.1% ios-base
16408 0.0% 0.0% 0.0% fh_fd_rf.proc
16409 0.0% 0.0% 0.0% fh_fd_oir.proc
16410 0.0% 0.0% 0.0% fh_fd_env.proc
16411 0.0% 0.0% 0.0% fh_fd_cli.proc
16412 0.0% 0.0% 0.0% fh_metric_dir.proc
16413 0.0% 0.0% 0.0% fh_fd_test.proc
16414 0.0% 0.0% 0.0% fh_fd_snmp.proc
16415 0.0% 0.0% 0.0% fh_fd_none.proc
16416 0.0% 0.0% 0.0% fh_fd_intf.proc
16417 0.0% 0.0% 0.0% fh_fd_gold.proc
16418 0.0% 0.0% 0.0% fh_fd_timer.proc
16419 0.0% 0.0% 0.0% fh_fd_ioswd.proc
16420 0.0% 0.0% 0.0% fh_fd_counter.proc
16421 0.0% 0.0% 0.0% fh_server.proc
16422 0.0% 0.0% 0.0% fh_policy_dir.proc
16423 0.0% 0.0% 0.0% call_home.proc
Please find the output attached.
Murali
Edison Ortiz Mon, 07/19/2010 - 10:30
  • Hall of Fame,
    Founding Member
Murali,
My suggestion is to open a TAC case for proper troubleshooting. It seems you are running the modular IOS version on this 6500 and you may be experiencing a memory leak. TAC can indicate if there is a bug on the IOS that you are running and provide an IOS recommendation with the bug fix.
Edison.
datapex Mon, 07/19/2010 - 13:11
I'm not sure what ios rev you're running but there is a memory corruption issue with 12.2(33)SXI3 - bugid CSCtb34857 - crashed seen in xdr_reference.
Related Content
