Question about real-life multicast implementation
Answered Question
Jul 19th, 2010
Hello all. I've been doing a lot of multicast practice labs and so far I am getting a good understanding of how it works. However, I am still struggling with how it works in a real life scenario.
My particular question is - when configuring and testing multicast routing in the lab, because I dont have source servers and real PC hosts, I use switches to emulate the server and the client. In order to emulate the IGMP client I input the following command on a client access switchport - Ip igmp join-group  <multicast address> command. My question is - In a real life scenario where the client PCs are connected to a layer 2 access switchport, how will a client typically 'join group'?  How does a client receive a multicast video stream in a real life implementation? Thanks.
Correct Answer by Edison Ortiz about 6 years 6 months ago
By launching a multicast enabled application. The application is configured to join a specific multicast group (IP address).
If there are servers sending to that group, the clients that have joined that group will begin listening to the stream.
Just think about turning your TV on, you only get to see Channel X if you tune into Channel X. However, if you don't tune into Channel X - it doesn't mean Channel X will stop sending information for others willing to tune in
Edison.
Correct Answer by Tharak Abraham about 6 years 6 months ago
Windows media player and VLC supports IGMP joins AFAIK.
Tried this long time back though.
VLC is much easier for Joins and even stream a Mcast file -:)
Real life scenarios also involves clicking URD or even Cable TV operations.
Overall Rating: 5 (2 ratings)
Correct Answer
Tharak Abraham Mon, 07/19/2010 - 11:05
Correct Answer
Edison Ortiz Mon, 07/19/2010 - 11:26
Edison.
