Call Forwarding issue in CUCM 7.1.3.
Jul 19th, 2010
Hi I’m having problems with Call Forwarding. The scenario is below what I’m trying to achieve.
Call comes in to main DN number phone, if it is not answered after 3 rings it forwards to next number configured i.e. his 2nd line. If it does not answer within 3 rings the call goes back to the voicemail.
This is use to work in my old version of Call manager but couple of days back we have upgraded to 7.1.3 & the problem started.
Any help is most appreciated.
Jaime Valencia Mon, 07/19/2010 - 09:56
  • Cisco Employee,
  • Hall of Fame,
    2011
So what behavior are you observing right now?
Is VM working fine if you press VM?
Does the N line you hunt has the forward to VM?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
srinivas.pendyala Mon, 07/19/2010 - 10:10
We are having issues right now & my VM is working fine. Actually if the line 1 is busy it should go to line 2 & if it is not answered it should reach to VM but the call is getting disconnecting before it reaches to line 2.
Srinivas.
Gabriel Saavedra Mon, 07/19/2010 - 10:15
  • Silver, 250 points or more
Can you reach the voice mail from your second line?...check Calling Search Space.
Gabriel
Jaime Valencia Mon, 07/19/2010 - 10:55
  • Cisco Employee,
  • Hall of Fame,
    2011
Is this for all calls?
External and/or internal?
Have you tried doing a dummy change??
I mean remove the DNs from CF, save, insert the DNs in CF fields, save. Then test?
java
srinivas.pendyala Fri, 07/30/2010 - 08:39
Sorry Guys,
I was sick & out of office still today. My issue is still pending & was escalated to Cisco TCA by Manager. I'll update the post once i find the answer. Once again thanks to everyone for all the suggestions.
Srinivas.
