877 nat issue
Jul 19th, 2010
have 877 series router with adsl modem interface build in.
dialergroup assigned to atm interface
using unnumber ip , memebr of vlan1
int vlan assigend with public ip address.
2 other devices with public ip address connected to router
need to connect 3rd device on private ip address and nat traffic from it address as inside to a public ip in overload  configuration.
having trouble getting it to work.
Giuseppe Larosa Mon, 07/19/2010 - 13:40
  • Hall of Fame,
    Founding Member
Hello Keith,
to put a physical FE port in Vlan2 you need additional commands
interface FastEthernet3
!interface conntected to devices on vlan2
You should have:
int fas3
switchport
switchport mode access
switchport access vlan 2
the Fas ports are like switch ports in a Cisco IOS LAN switch
Hope to help
Giuseppe
Keith Craycraft Tue, 07/20/2010 - 05:00
The following commands are in the config:
int fas3
switchport
However when I try to access web site or ping from vlan 2 host  it times out.
I can ping vlan 2 ip address.  and the outside interface of the router from vlan 2.
if i do a Show IP NAT STATS  it shows me what is inside and outside interfaces information but  thats it.
the sh ip nat translations shows nothing.
for some reason its just not doing the translations.
