autocomplete="off" on VPN SSL
Jul 19th, 2010
Hi Network Team,
I recently set up a VPN SSL for a customer, but when they access their application the VPN is changing the page code, like the example below:
Original Code:
<input  type="text"  size=20  maxlength=8  name= "txt_Codigo"  VALUE=>
Code Changed by VPN SSL
<input  type="text"  size=20  maxlength=8  name= "txt_Codigo"  VALUE= autocomplete="off">
SelGer.retorna_Url=function(){
var url=new String()
url=window.location.toString(); webvpn_unmangle_location(//window.location,WEBVPN_LOC_PATHNAME);
for (var i=url.length-1; i>0;i--){
  if (url.charAt(i)=="\\" || url.charAt(i)=="/" ){
   return url.substring(0,i)
I attached 2 imagens, the first one "Correct" show the application function correctly; and the second one "Incorrect" show the application function incorrectly.
I previously would like to thanks the help!
Rodrigo Alves
gurdsing Tue, 07/20/2010 - 17:00
This looks like a bug to me. Open a TAC case to get someone look for a bug to this problem.
Guru.
