ASA RAVPN: Single Certificate Auth -> 2 IP address pools segmentation
I am working on a particular problem of assign multiple groups of VPN users to 2 separate IP address pools. The issue is easily solvable using group authentication, since you can bind an IP address pool to a group in Cisco ASA configuration:
hostname(config)# tunnel-group testgroup type ipsec-ra
hostname(config)# tunnel-group testgroup general-attributes
hostname(config-general)# address-pool testpool
hostname(config)# tunnel-group testgroup ipsec-attributes
When I configure a VPN client to use a digital certificate, this option of selecting a “group” goes away. Is it possible to segment groups of VPN users to different IP pools, when they are auth-ing with certificates? Some ideas I have:
-        Use to different trustpoints: messy because each client has to be issues new certificates or
-        Somehow bind group1 to a different external ASA ip address: don’t know if I can configure multiple IP address to support different VPN’s on one ASA?
-        Explore “mutual group authentication”: the definition is confusing in itself however and I cannot even decide what it does and if it will work for this.
-        Any other ideas?
Thanks in advance for any ideas.
