limited priv on router/switch
Jul 19th, 2010
Hello
How do I allow  a user with limited command privilege on a router and switch
user once ssh to the router or switch can run these command on the router.
show cdp neigh
show ip interface brief
ping
user will be created locally  on the switch or router
==== I tested this but doesnt work ===============
aaa authentication login default local
aaa authorization exec default local
username admin priv 15 password abcd
username  helpdesk priv 0 password helpdesk
priv exec level 0 ping
priv exec level 0 sh interface
priv exec level 0 show cdp neigh
priv exec level 15 clear line
line vty 0 4
priv level 15
tranport input telnet ssh
thanks
ST
Chetan Kumar Ress Mon, 07/19/2010 - 13:35
Hi Saquib
You should not user privi 15 user line vty.  Without configuring AAA you can use below command to achive what you want.
priv exec level 15 clear line  ---- no need to config this command , Priv 15 is having  all access
line vty 0 4
login local
Chetan Kumar
Ganesh Hariharan Mon, 07/19/2010 - 22:52
Hello
show cdp neigh
ping
line vty 0 4
priv level 15
thanks
ST
Hi ST,
In order to create local data base you can use the command to create a user database
username admin priv 15 password cisco
username bob priv 7 password cisco
Following username will be assign with privillage 15 and 7 respectively,Once these users are created, you need to enable the login on the lines  to use the local database instead of just the line password, or no  password at all.
To tell each line to use these new user logins, you must go to each line  and perform the login local command.
and in order to restrict some privillage level to use the command check out the below link for ios privillage level command in cisco
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a00800949d5.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
