CUCM 8 Questions
Jul 19th, 2010
I am going to upgrade to CUCM 8 very soon.  I have a few questions for the community.
  • When upgrading from 6.1.2 to 8 are there any issues to look out for?  It looks like it should be no problem.
  • Does it still support the 7960G phones with SCCP?
  • It says that version 8 supports caller ID with MGCP and FXO.  What is the process of converting an H323 gateway to MGCP?
Jaime Valencia Mon, 07/19/2010 - 13:52
AC is dropped so if you're using it plan accordingly by either also dropping it or look into the CUxAC suite that is the replacement.
Supported phones are listed here:
Table 19     Default Loads for Cisco Unified Communications Manager Release  8.x
This should give you the basics, make sure you have read the pre-requisites for caller ID MGCP with FXO.
Configure MGCP Gateway and FXO/FXS Ports on a   Cisco CallManager Server
Configuring Cisco CallManager with IOS MGCP  Gateways (Analog FXO, FXS Ports)
If this helps, please rate
