Url-cache not working on Pix 535
Jul 19th, 2010
Running 7.22.
url-server (DMZ1) vendor websense host x.x.x.x timeout 10 protocol TCP version 4 connections 5
url-cache dst 128
filter url http 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 allow
url-block url-mempool 1500
url-block url-size 4
PIX535HOFWS# show url-server statistics
Global Statistics:
URLs total/allowed/denied         22524/20050/2474
URLs allowed by cache/server      0/20050
URLs denied by cache/server       0/2474
HTTPSs total/allowed/denied       0/0/0
HTTPSs allowed by cache/server    0/0
HTTPSs denied by cache/server     0/0
FTPs total/allowed/denied         0/0/0
FTPs allowed by cache/server      0/0
FTPs denied by cache/server       0/0
Requests dropped                  0
Server timeouts/retries           0/0
Processed rate average 60s/300s   6/9 requests/second
Denied rate average 60s/300s      0/0 requests/second
Dropped rate average 60s/300s     0/0 requests/second
Server Statistics:
x.x.x.x                       UP
  Vendor                          websense
  Port                            15868
  Requests total/allowed/denied   22524/20050/2474
  Responses received              22524
  Response time average 60s/300s  0/0
URL Packets Sent and Received Stats:
Message                 Sent    Received
STATUS_REQUEST          464     464
LOOKUP_REQUEST          22537   22537
LOG_REQUEST             0       NA
Errors:
RFC noncompliant GET method     0
URL buffer update failure       0
URL Filter Cache Stats
Entries :        219
  In Use :         0
Lookups :     9182
    Hits :          0
Hit Rate :         0
URL  blocking is working properly, but Caching isn't.  Do I have to do anything on the websense server to enable this?  I didn't think so, but not sure why it's not working at all...
Overall Rating: 5 (1 ratings)
David White Sat, 07/24/2010 - 06:42
  • Cisco Employee,
What version of Websense are you using?
I guess first, I need to explain how caching works.  When the PIX sends a request to Websense, in the permit/deny reply there is a field which tells the PIX whether it can cache that response.  Only if the field is set to true, and caching is enabled on the PIX, will it cache the replies.
However, in all newer versions of Websense/N2H2, they no longer permit the responses to be cached (meaning the field is set to false in all responses).  Therefore, even though the PIX can cache the response, it is not permitted to.
The reason for doing this is because many sites can change classification, or more importantly, sites are very large these days and different areas of sites can be classified to different categories.  With caching, the entire domain must be in the same category so the the action taken on the entire domain is the same.  This is because only the domain is cached with a permit/deny action, not the entire URL.
Hope that helps explain it.  If so, please ensure you mark the question as answered so we know it solved the problem.
Sincerely,
David.
Related Content
