NAC Profiler - NetWatch : "Invalid configuration file (missing InternalAddress)"
I'm trying to configure the NAC Profiler with a 3310 CAS Collector. In the "Edit Collector" menú, it shows all the modules as "Running", except for the NetWatch module which shows a state "Invalid configuration file (missing InternalAddress)".
I configured the eth3 interface of the CAS as a monitor interface in the Profiler (see attached image), and I tested that the SPANed traffic actually reaches that interface from the access switch.
I'm using software version 3.1.0_24 in both the Profiler and the Collector.
I'd appreciate any help in setting up the NetWatch module.
Edit:
I must add that I already checked the Cisco documentation, but all I found is that this message appears when the monitor interface is not configured for this module, which I think is not the case.
