Upgraded ASA 5520 memory for 8.3(1), now ASA reports high memory utilization
Answered Question
Jul 19th, 2010
I upgraded our 5520 to 8.3(1) last week and also upgraded the memory. If I do a "show memory" on the ASA, it reports the following:
lsfw01# sho memory
Free memory:      2313296496 bytes (108%)
Used memory:      4129154448 bytes (192%)
Total memory:     2147483648 bytes (100%)
lsfw01#
ASDM 6.3(1) also reports the same thing.  I used Cisco memory for this upgrade.  What would cause this?
Correct Answer by Nagaraja Thanthry about 6 years 6 months ago
You might be hitting a software defect CSCth13899. You need to remove the
original memory from the chassis before installing the new memory.
Hope this helps.
NT
Overall Rating: 5 (1 ratings)
Correct Answer
Nagaraja Thanthry Mon, 07/19/2010 - 15:11
Hope this helps.
NT
troymaki Tue, 07/20/2010 - 06:28
That's exactly it.  I removed the old memory out of the first 5520 but did not do it on this one.
Thanks for the bug id's.
