Cannot Access GUI in WLC
Jul 19th, 2010
I have two WLC4404  with version 6.x in the same VLAN, same mobility group, same SSID, same interfaces, of course, with different IP Address, just the Virtual IP Address is the same in both devices. Well, I cannot access via GUI the second WLC, but when I turn off the first WLC1, then I can access second WLC.
If both of them are connected, I just can access WLC1, but not WLC2.
Any ideas?
dancampb Tue, 07/20/2010 - 06:41
Is the PC you are using to access the controller's GUI attached to the network wirelessly?  You may have to enable management via dynamic and access the second controller through its dynamic interface.
moises.rodriguez Tue, 07/20/2010 - 07:48
I forgot to say that Mgmt via wireless is enabled on both controllers, also, the same thing happens
when you try to reach the controller vi ethernet cable.
Related Content
Trending Topics - Security & Network
