Enabling WAN on 861W
Jul 19th, 2010
I've a cable modem attached to the WAN interface (FE4) of a new 861W. The interface is configured as a dhcp client.The WAN LED does not come on when the router is attached to the modem.  What am I doing wrong?
Using 4227 out of 262136 bytes
! Last configuration change at 18:22:40 CST Sun Feb 28 1993 by admin
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname 861W
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
enable secret 5 $1$fT/U$UBWQYmc.cNTE.aZjnKT5E.
no aaa new-model
memory-size iomem 10
clock timezone CST -6
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-460023439
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-460023439
revocation-check none
rsakeypair TP-self-signed-460023439
crypto pki certificate chain TP-self-signed-460023439
certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
no ip source-route
ip dhcp excluded-address 10.10.10.1 10.10.10.99
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp pool ccp-pool1
   import all
   network 192.168.1.0 255.255.255.0
   dns-server 209.18.47.61 209.18.47.62
   default-router 192.168.1.1
   domain-name specterinstruments.local
   lease 0 2
ip cef
no ip bootp server
ip domain name specterinstruments.local
ip name-server 209.18.47.61
ip name-server 209.18.47.62
license udi pid CISCO861W-GN-A-K9 sn FTX14208243
username admin privilege 15 secret 5 $1$nSfP$tGrUQM4cJLbR6x2QhCyCX1
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$
ip address dhcp client-id FastEthernet4
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip tcp adjust-mss 1452
interface Vlan2
ip address 10.10.2.1 255.255.255.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
no cdp run
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you
want to use.
^C
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Nagaraja Thanthry Mon, 07/19/2010 - 20:08
  • Cisco Employee,
Can you connect a workstation to the cable modem Ethernet handoff and see if you are getting an IP from the ISP? If you did not get an IP, then I would suggest you contacting your ISP.
Hope this helps.
NT
chris_specter Tue, 07/20/2010 - 08:08
I managed to plug the modem into the console port instead of the WAN port.
Because it's during business hours, I can't plug the router directly into the cable modem. I have it plugged into our network which has one router on it with the cable modem on the wan side and the 861W on the other side as well as the rest of our network. The 861W is pulling an IP address from the other router and I can ping any machine on the rest of the network from the 861W. I cannot ping any machine from my client computer though, which is connected to the 861W.
tcarternyc Tue, 09/14/2010 - 09:48
Generally it sounds like the routing on your 861w might not be configured correctly. You might want to confirm the routing gateway for internet access points to the WAN side IP address of the 861w. I'd think this is the private IP address being assigned by the other router. The 861w should have a route to the outer network and dhcp assigned to be issued to clients connecting from the LAN side of the 861w.
Hope that helps,
Tommie Carter
omar.elmohri Sat, 09/18/2010 - 10:13
Please attach the output for:
show interface
show ip interface
show ip interface brief
mrmoothe Wed, 09/22/2010 - 06:36
Chris,
Can you try replacing the ip address on fa4 with just
ip address dhcp
without the client id and see whether you get an ip address.
Sometimes you need a reboot of the cable modem to achieve the same...
If the above does not work...
Try,
ip address negotiated (If you router supports is)
and see whether this gives you an ip address.
Lets first get an ip address on Fa4 from your cable modem. Once we do that we can move onwards to the internet access part.
