PSTN connections are having disconnection issues with conferencing while CUCM registered phones dont
Answered Question
Jul 19th, 2010
Hi Everyone
I Cant make a conference call when two partys are from PSTN ...... I can make a conference call between three party when all the there parties are registered to cucm (ie ip phone)..... However, when two parties are from pstn and one party is from my CUCM ip phone network .. Conference calls
get disconnected ... Another observation is .. If two parties are from cucm ip phone  and one party is from PSTN ... on pressing
conference button.. the PSTN gets disconnected .. the other two ip phones are not disconnected ...
To Summarise .. PSTN connections are having disconnection issues with conferencing while CUCM registered phones dont...
My Voice gateway to PSTN is Cisco 3845 router.  The IOS version is "c3845-ipvoicek9-mz.124-11.XW9.bin"
Please find below voice details from output of "Show run"
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
voice-card 1
dspfarm
voice service voip
modem passthrough nse codec g711ulaw
voice class h323 1
h225 timeout tcp establish 3
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/2/0
input gain 7
connection plar opx 8000
caller-id enable
voice-port 0/2/1
input gain 7
caller-id enable
voice-port 0/2/2
input gain 7
caller-id enable
voice-port 0/2/3
input gain 7
caller-id enable
voice-port 0/3/0
input gain 7
caller-id enable
voice-port 0/3/1
input gain 7
caller-id enable
voice-port 0/3/2
input gain 7
caller-id enable
voice-port 0/3/3
input gain 7
caller-id enable
voice-port 1/0:15
dial-peer voice 100 voip
preference 9
destination-pattern 8...
voice-class h323 1
session target ipv4:10.10.4.11
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 200 pots
destination-pattern 9T
incoming called-number 8...
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 300 pots
port 1/0:15
dial-peer voice 400 voip
description " Fax ATA "
dtmf-relay h245-signal
codec g711ulaw
fax rate disable
no vad
dial-peer voice 500 pots
destination-pattern 9[2-8]......
port 0/2/0
forward-digits 7
dial-peer voice 501 pots
port 0/2/1
forward-digits 7
dial-peer voice 502 pots
port 0/2/2
forward-digits 7
dial-peer voice 503 pots
port 0/2/3
forward-digits 7
dial-peer voice 504 pots
port 0/3/0
forward-digits 7
dial-peer voice 505 pots
port 0/3/1
forward-digits 7
dial-peer voice 506 pots
port 0/3/2
forward-digits 7
dial-peer voice 507 pots
port 0/3/3
forward-digits 7
dial-peer voice 101 voip
voice-class h323 1
session target ipv4:10.10.4.12
no vad
dial-peer voice 301 pots
destination-pattern 9600T
port 1/0:15
prefix 600
dial-peer voice 302 pots
destination-pattern 9800T
port 1/0:15
prefix 800
dial-peer voice 102 voip
preference 8
destination-pattern 1...
voice-class h323 1
no vad
dial-peer voice 103 voip
preference 2
voice-class h323 1
no vad
Correct Answer by Jaime Valencia about 6 years 10 months ago
CUCM CFB only supports G711.
Many of the VOIP DPs you have are using the default codec which is G729.
Make sure the call legs and your configuration is set to G711
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Tue, 07/20/2010 - 07:06
  • Cisco Employee,
  • Hall of Fame,
    2011
java
sandeep.menon Tue, 07/20/2010 - 23:24
Thanks Dear
I added manually the 711ulaw codecs as advised and now the conference does not get disconnected.
Thank You so much.
Sandeep
sandeep.menon Wed, 07/21/2010 - 00:15
Thanks Dear
Thank You so much.
Sandeep
Related Content
