Information Required
Jul 19th, 2010
I have recently certified CCNA (640-802) on 16th July, 2010. So, can anyone please help me out, which next certification i should opt for ? I am thinking about direct go for CCNP or CCSA. Please suggest.
Thanking you.......
With Regards,
Tuhin
cisco.xenpak1 Thu, 08/12/2010 - 03:14
Hello Tuhi,
this all depends where you are planing to work or go in your future.
Certainly you could go CCNP or any other professional certificate.
But I would recommend you to go the direction where you can also build hands-on experience.
For instance, if you go to work for an ISP then would recommend CCIP; for a LAN environment would do CCNP or cover the WLAN and VoIP technology.
Now that you passed you have 3 years until the CCNA expieres.
I strongly recommend NOT TO WAIT till the last minute to recertify, rather take your time and just go for a WLAN or CCNP Routing CCNP Switching test.
If you send more info, what you are planing to do, it is possible to guid you a little bit more into the right direction.
Chris
