%IP-3-DESTHOST : how to fix it?
Jul 20th, 2010
I experience a problem about transferring calls from an CUE 7.1 auto attendant console to CCM4.
Calls are comming in a 1st gateway (GW-1),
and it is forwarded to the Autoattendant (aa.aef) that is in the CUE in another CUCME router.(GW2)
The operator is in the CUCM 4.2.
Scenario :
0. caller A make call trhoug an E1 PRI.
1. call arrive int GW-1 (that has PRI)
2. Call is Transfered to CUE (GW-2) auto attendant
3. from CUE calle A push 0 to call the operator
4. Operator is in a CUCM, and  phone ring
5. Operator want to trransfert to a destination B (eg using transfer full consult)
5.1 When transfer : the end destination (B) hears the operator
5.2 after pushing the buttun "transfer", the call seems be transfered.
5.3 Caller A cannot hear caller B. and call is disconnected.
Is there any solution?
CUCME router (GW2) give the error :
Jul 20 08:39:17.443: %IP-3-DESTHOST: src=10.11.4.2, dst=0.0.0.0, NULL desthost -Process= "VOIP_RTCP", ipl= 0, pid= 308,  -Traceback= 0x418B162C 0x41FD331C 0x41FD4334 0x41FD491C
Jul 20 08:39:21.711: %IP-3-DESTHOST: src=10.11.4.2, dst=0.0.0.0, NULL desthost -Process= "VOIP_RTCP", ipl= 0, pid= 308,  -Traceback= 0x418B162C 0x41FD331C 0x41FD4334 0x41FD491C
Jul 20 08:39:25.763: %IP-3-DESTHOST: src=10.11.4.2, dst=0.0.0.0, NULL desthost -Process= "VOIP_RTCP", ipl= 0, pid= 308,  -Traceback= 0x418B162C 0x41FD331C 0x41FD4334 0x41FD491C
Jul 20 08:39:30.575: %IP-3-DESTHOST: src=10.11.4.2, dst=0.0.0.0, NULL desthost -Process= "VOIP_RTCP", ipl= 0, pid= 308,  -Traceback= 0x418B162C 0x41FD331C 0x41FD4334 0x41FD491C
Jul 20 08:39:33.295: %IP-3-DESTHOST: src=10.11.4.2, dst=0.0.0.0, NULL desthost -Process= "VOIP_RTCP", ipl= 0, pid= 308,  -Traceback= 0x418B162C 0x41FD331C 0x41FD4334 0x41FD491C
Jul 20 08:39:39.855: %IP-3-DESTHOST: src=10.11.4.2, dst=0.0.0.0, NULL desthost -Process= "VOIP_RTCP", ipl= 0, pid= 308,  -Traceback= 0x418B162C 0x41FD331C 0x41FD4334 0x41FD491C
The result of error decoder is in this link :
http://www.cisco.com/cgi-bin/Support/Errordecoder/index.cgi?action=search&locale=en&index=all&query=%25IP-3-DESTHOST&counter=0&paging=5&links=reference&sa=Submit
! GW2 IOS is: Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(22)YB, RELEASE SOFTWARE (fc2)
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
dial-peer voice 2672 voip
description to AAttendant
destination-pattern 2672
session protocol sipv2
session target ipv4:10.11.4.3
dtmf-relay rtp-nte
codec g711ulaw
There is a transcoder, MTP, CFB
regards,
Antra
jsliwinski Tue, 07/20/2010 - 13:50
This can be IP connectivity issue between your gateway and IP phone B.  As a result RTP stream from phone B to Gateway does not make it.
"5.3 Caller A cannot hear caller B."
1. What is the IP address of  GigabitEthernet0/0
Try to do extended ping from the gateway using GigabitEthernet0/0 address and the IP address of the phone B.  If you do not get reply this is your answer you need to fix IP connectivity.
-- j
iantra123 Wed, 07/21/2010 - 07:10
I call directly the CUCME to phone B.
Everything is ok.
I called directly from a phone A(PRI)  to phone B : ok
But if the call goes from A ->CUA-AA -> Operator -> B :call is cuted when A is transfered to B.
