07-20-2010 02:23 AM - edited 03-06-2019 12:06 PM
hey i have 1 doubt
suppose if i created vlan for 5 pc's,and i want to multicast message from my 1st pc to 3rd n 4th pc only,i dont want to send that message to pc 2 n 5,is it possible in my created vlan or i have to create another one? if possible then tell me the procedure?waiting 4 reply
Solved! Go to Solution.
07-20-2010 05:06 AM
As long as you enable IGMP snooping and PC 3 & 4 join the multicast group,
only they will get the data (on a multicast capable switch). If the switch
is not capable of handling multicast traffic, then it will treat it as
broadcast and all ports (or all PC's) will get the traffic.
Hope this helps.
NT
07-20-2010 05:06 AM
Hope this helps.
NT
07-20-2010 05:10 AM
Dear Gaurang,
With the help of Private VLAN, we can isolate the PC's in the same VLAN..
This following links will be helpful for configuring Private VLAN
http://www.cisco.com/en/US/tech/tk389/tk814/technologies_configuration_example09186a008017acad.shtml
http://cisco.biz/en/US/products/hw/switches/ps700/products_tech_note09186a008013565f.shtml
This will be helpful for configuring private VLAN.
Senthil
