CUCCX re-run
Jul 20th, 2010
Hello Fellas!
how are you doing today? hope you are all doing well.I am labbing cuccx7 on vmware. did some integration with cucm7. now i wanna re-run initial setup again, i forgot to take snapshot from cuccx. how can I re-run initial config, or reset cuccx to factory defaults?
thank you very much in advance..
Aaron Harrison Tue, 07/20/2010 - 05:32
  • Community Spotlight Award,
    Member's Choice, May 2015
See this post : https://supportforums.cisco.com/message/1044177#1044177
It describes how to use cet to set the appadmin setup wizard back to FRESH_INSTALL state which allows you to rerun the appadmin setup.
It doesn't clear out the scripts/apps/prompts or any other settings, it's principally to recover admin access and so on.
If you actually want to clear out all data, the only real way is to flatten the box (or just go through each admin page and delete things, and perhaps purge the historical data).
Aaron
Please rate helpful posts..
Dennis Aston Tue, 07/20/2010 - 07:25
Don't forget to clear out any ports and users that were auto-created in CUCM as well.  Can't have those there when you start the setup wizard or the rmcm wizard.
