ASA is making a high pitched whining noise at regular intervals (every half an hour or so)
Answered Question
Jul 20th, 2010
ASA is making a high pitched whining noise at regular intervals (every half an hour or so). Initial review of logs do not show root cause.
Correct Answer by Panos Kampanakis about 6 years 8 months ago
I would suggest to check if the CPU is high at the time. And also try to see where the noise is from (i.e. fan)
It could be a hardware issue, but you should try to correlate the noise with what is happening on the box in terms of load.
I hope it helps.
PK
Overall Rating: 5 (1 ratings)
Correct Answer
Panos Kampanakis Tue, 07/20/2010 - 06:17
  • Cisco Employee,
I hope it helps.
PK
