Wireless local radius authentication
Jul 20th, 2010
Greetings,
I have a AIR-AP1121G-A-K9, and I would like to authenticate users with a username and password on the AP using the local radius server.
I used the configuration at http://www.aironet.info/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801c0912.shtml
and tried a couple other posted configuration, but are running into the same issue regardless of which method I am using.
show ver
Cisco IOS Software, C1100 Software (C1100-K9W7-M), Version 12.3(8)JED1, RELEASE
SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 27-Apr-10 12:52 by alnguyen
ROM: Bootstrap program is C1100 boot loader
BOOTLDR: C1100 Boot Loader (C1100-BOOT-M) Version 12.2(8)JA, EARLY DEPLOYMENT RE
LEASE SOFTWARE (fc1)
ORP_ROOFDECK uptime is 21 hours, 3 minutes
System image file is "flash:/c1100-k9w7-mx.123-8.JED1/c1100-k9w7-mx.123-8.JED1"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-AP1121G-A-K9     (PowerPCElvis) processor (revision A0) with 15138K/12
36K bytes of memory.
Processor board ID FOC08370K83
PowerPCElvis CPU at 197Mhz, revision number 0x0950
Last reset from power-on
1 FastEthernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:12:01:6B:86:46
Part Number                          : 73-7886-07
PCA Assembly Number                  : 800-21481-07
PCA Revision Number                  : A0
PCB Serial Number                    : XXX
Top Assembly Part Number             : 800-22053-04
Top Assembly Serial Number           : XXX
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1121G-A-K9
Configuration register is 0xF
show run
Current configuration : 4240 bytes
version 12.3
no service pad
service password-encryption
hostname XXX
ip subnet-zero
ip domain name XXX!
ip ssh version 2
aaa new-model
aaa group server radius rad_eap
server 172.16.1.35 auth-port 1812 acct-port 1813
aaa group server radius rad_acct
aaa authentication login eap_methods group rad_eap
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 syslog
dot11 ssid YYY
   authentication open eap eap_methods
   authentication network-eap eap_methods
   guest-mode
bridge irb
interface Dot11Radio0
no ip address
ip helper-address 172.16.1.1
no ip route-cache
encryption key 1 size 128bit 7 66061D688B874859701297485642 transmit-key
encryption mode wep mandatory
broadcast-key change 300
ssid YYY
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
channel 2437
station-role root
rts threshold 2312
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 172.16.1.35 255.255.255.0
no ip route-cache
ip default-gateway 172.16.1.1
ip http server
ip http authentication local
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server local
  no authentication eapfast
  no authentication mac
  nas 172.16.1.35 key 7 VVV
  group YYY
    ssid YYY
    block count 3 time 30
    reauthentication time 300
  user zzz nthash 7 0225540F2A2429741C162F3C2636455854560E72760A6A667B315E37
5553010B7A group YYY
radius-server attribute 32 include-in-access-req format %h
radius-server host 172.16.1.35 auth-port 1812 acct-port 1813 key 7 VVV
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
access-class 10 in
line vty 5 15
end
Debug Output:
331: AAA/ACCT(00000000): add node, session 4
*Mar  1 21:37:37.331: AAA/ACCT/NET(00000004): add, count 1
*Mar  1 21:37:37.331: dot11_auth_add_client_entry: Create new client 0023.6c85.3
2cd for application 0x1
*Mar  1 21:37:37.331: dot11_auth_initialize_client: 0023.6c85.32cd is added to t
he client list for application 0x1
*Mar  1 21:37:37.331: dot11_auth_add_client_entry: req->auth_type 4
*Mar  1 21:37:37.331: dot11_auth_add_client_entry: auth_methods_inprocess: 2
*Mar  1 21:37:37.331: dot11_auth_add_client_entry: eap list name: eap_methods
*Mar  1 21:37:37.331: dot11_run_auth_methods: Start auth method EAP or LEAP
*Mar  1 21:37:37.331: dot11_auth_dot1x_start: in the dot11_auth_dot1x_start
*Mar  1 21:37:37.331: dot11_auth_dot1x_send_id_req_to_client: Sending identity r
equest to 0023.6c85.32cd
*Mar  1 21:37:37.332: EAPOL pak dump tx
*Mar  1 21:37:37.332: EAPOL Version: 0x1  type: 0x0  length: 0x0036
*Mar  1 21:37:37.332: EAP code: 0x1  id: 0x1  length: 0x0036 type: 0x1
00ECBA00: 01000036 01010036 01006E65 74776F72  ...6...6..networ
00ECBA10: 6B69643D 4F52505F 5075626C 69632C6E  kid=YYY,n
00ECBA20: 61736964 3D4F5250 5F524F4F 46444543  asid=YYY
00ECBA30: 4B2C706F 72746964 3D30               K,portid=0
*Mar  1 21:37:37.333: dot11_auth_send_msg:  sending data to requestor status 1
*Mar  1 21:37:37.333: dot11_auth_send_msg: Sending EAPOL to requestor
*Mar  1 21:37:37.333: dot11_auth_dot1x_send_id_req_to_client: Client 0023.6c85.3
2cd timer started for 30 seconds
*Mar  1 21:38:07.333: dot11_auth_dot1x_run_rfsm: Executing Action(CLIENT_WAIT,TI
MEOUT) for 0023.6c85.32cd
*Mar  1 21:38:07.333: dot11_auth_dot1x_send_client_fail: Authentication failed f
or 0023.6c85.32cd
*Mar  1 21:38:07.333: dot11_auth_send_msg:  sending data to requestor status 0
*Mar  1 21:38:07.333: dot11_auth_send_msg: client FAILED to authenticate 0023.6c
85.32cd, node_type 64 for application 0x1
*Mar  1 21:38:07.333: dot11_auth_delete_client_entry: 0023.6c85.32cd is deleted
for application 0x1
*Mar  1 21:38:07.334: %DOT11-7-AUTH_FAILED: Station 0023.6c85.32cd Authenticatio
n failed
*Mar  1 21:38:07.334: AAA/ACCT/HC(00000004): Update DOT11/00A83CE0
*Mar  1 21:38:07.335: AAA/ACCT/HC(00000004): DOT11/00A83CE0 [pre-sess] (rx/tx) b
ase 0/0 pre 6861/188 call 6861/188
*Mar  1 21:38:07.335: AAA/ACCT/HC(00000004): DOT11/00A83CE0 [pre-sess] (rx/tx) a
djusted, pre 6861/188 call 0/0
*Mar  1 21:38:07.335: AAA/ACCT/HC(00000004): Deregister DOT11/00A83CE0
*Mar  1 21:38:07.335: dot11_auth_client_abort: Received abort request for client
0023.6c85.32cd
*Mar  1 21:38:07.335: dot11_auth_client_abort: No client entry to abort: 0023.6c
85.32cd for application 0x1
*Mar  1 21:38:07.335: AAA/ACCT/EVENT/(00000004): CALL STOP
*Mar  1 21:38:07.335: AAA/ACCT/CALL STOP(00000004): Sending stop requests
*Mar  1 21:38:07.336: AAA/ACCT(00000004): Send all stops
*Mar  1 21:38:07.336: AAA/ACCT/NET(00000004): STOP
*Mar  1 21:38:07.336: AAA/ACCT/NET(00000004): Method list not found
*Mar  1 21:38:07.336: AAA/ACCT(00000004): del node, session 4
*Mar  1 21:38:07.336: AAA/ACCT/NET(00000004): free_rec, count 0
*Mar  1 21:38:07.336: AAA/ACCT/NET(00000004) reccnt 0, csr TRUE, osr 0
*Mar  1 21:38:07.337: AAA/ACCT/NET(00000004): Last rec in db, intf not enqueued
*Mar  1 21:41:34.645: AAA/BIND(00000005): Bind i/f
*Mar  1 21:41:34.645: AAA/ACCT/EVENT/(00000005): CALL START
*Mar  1 21:41:34.645: Getting session id for NET(00000005) : db=C4EBC0
*Mar  1 21:41:34.645: AAA/ACCT(00000000): add node, session 5
*Mar  1 21:41:34.646: AAA/ACCT/NET(00000005): add, count 1
*Mar  1 21:41:34.646: Getting session id for NONE(00000005) : db=C4EBC0
*Mar  1 21:41:34.646: AAA/AUTHEN/LOGIN (00000005): Pick method list 'Permanent L
ocal'
*Mar  1 21:41:39.002: AAA/AUTHOR (0x5): Pick method list 'default'
*Mar  1 21:41:39.002: AAA/AUTHOR/EXEC(00000005): processing AV cmd=
*Mar  1 21:41:39.003: AAA/AUTHOR/EXEC(00000005): processing AV priv-lvl=15
*Mar  1 21:41:39.003: AAA/AUTHOR/EXEC(00000005): Authorization successful
Any ideas how I can get simple username/password working on an autonomous AP with local radius server?
Thank you,
dancampb Tue, 07/20/2010 - 07:37
  • Cisco Employee,
You could get a better idea of why the auth is being failed with the output of "show radius local-server statistics".  You could also run "debug radius local-server client" and "debug radius local-server error".
dbauman_wan Tue, 07/20/2010 - 08:00
It's also not even asking for the username/password.  I
dancampb Tue, 07/20/2010 - 08:01
  • Cisco Employee,
What supplicant are you using?
Is the supplicant have machine authentication enabled?
