cs-mars reimage
Jul 20th, 2010
I have CS-MARS model 20.
When I try to boot with recovery image it gives me the following message:-
LILO 22.2 LOADING LINUX
W01
W01
But the same dvd works fine in vmware setup.
I suspect issue with the applicance, but not sure about the message.
Any help on this issue....
Thanks in Advance
-G P
Justin Teixeira Tue, 07/20/2010 - 08:05
  • Bronze, 100 points or more
Hi G P,
   It sounds like you may be trying to perform the recovery from the console on the MARS.  The only supported method for recovery is to actually hook up a monitor and keyboard to the device and then reboot with the DVD in the drive.  Do you receive the same message from a directly connected keyboard/monitor?
Best Regards,
JT
