Problems pinging interface between VRF's
Jul 20th, 2010
On a VRF lab im trying to ping between VRF interfaces. "ping vrf 100 10.0.0.1" but get no reply on some interfaces.
Ive got three routers connected as below
R1------------------------------------R2----------------------------------R3
10.0.0.1/30       10.0.0.2/30    10.0.1.2/30                 10.0.1.1/30
VRF 100        VRF 100
From router R1 i can ping 10.0.0.2 & 10.0.1.2 but NOT 10.0.1.1
From router R3 i can ping 10.0.1.2 & 10.0.0.2 but NOT 10.0.0.1
From router R2 i can ping 10.0.0.1 & 10.0.1.1
Router R2 only is only routing between those two nets and have no VRF's configured.
What have i missed???
Short config below
R1
ip cef
ip vrf 100
rd 1:100
interface Ethernet1
ip vrf forwarding 100
ip address 10.0.0.1 255.255.255.252
duplex auto
ip classless
ip route vrf 100 10.0.1.0 255.255.255.252 10.0.0.2
R3
ip cef
         ip vrf 100
          rd 1:100
         interface Ethernet1
          ip address 10.0.1.1 255.255.255.252
          duplex auto
         ip classless
         ip route vrf 100 10.0.0.0 255.255.255.252 10.0.1.2
R2
ip cef
     interface Ethernet0
      ip address 10.0.0.2 255.255.255.252
      duplex auto
     interface Ethernet1
      ip address 10.0.1.2 255.255.255.252
      duplex auto
Overall Rating: 2 (1 ratings)
Tharak Abraham Tue, 07/20/2010 - 10:21
  • Bronze, 100 points or more
Do you have multiple links to the other router ?
If Yes, you need to recheck the interface status of 10.0.0.1 !
Please enable icmp debugs or ip packet detail with an access list for destination 10.0.0.1
I checked it out now and its working with the basic vrf ping.
Marcus Johansson Tue, 07/20/2010 - 23:09
Single link only between the routers.
Interface status of 10.0.0.1?? -i can ping 10.0.0.1 from R2.
And i can ping all but R3's interface from 10.0.0.1.
Any other ideas?
zdesve33 Wed, 07/21/2010 - 00:18
i remember - in some ios there is problem with source ip in vrf - is there another interface on R1,R3? Try to ping with specify source ip. And, of course, debug.
Marcus Johansson Wed, 07/21/2010 - 00:34
Some ping results from R1 to R2 and R3 with debugs
Router1#ping vrf 100 10.0.0.2 source eth 1
Sending 5, 100-byte ICMP Echos to 10.0.0.2, timeout is 2 seconds:
Packet sent with a source address of 10.0.0.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/8/20 ms
Router1#
*Mar  1 22:41:39.739: IP: tableid=1, s=10.0.0.1 (local), d=10.0.0.2 (Ethernet1), routed via FIB
*Mar  1 22:41:39.739: IP: s=10.0.0.1 (local), d=10.0.0.2 (Ethernet1), len 100, sending
*Mar  1 22:41:39.739:     ICMP type=8, code=0
*Mar  1 22:41:39.755: IP: tableid=1, s=10.0.0.2 (Ethernet1), d=10.0.0.1 (Ethernet1), routed via RIB
*Mar  1 22:41:39.759: IP: s=10.0.0.2 (Ethernet1), d=10.0.0.1 (Ethernet1), len 100, rcvd 3
*Mar  1 22:41:39.759:     ICMP type=0, code=0
*Mar  1 22:41:39.759: ICMP: echo reply rcvd, src 10.0.0.2, dst 10.0.0.1
*Mar  1 22:41:39.759: IP: tableid=1, s=10.0.0.1 (local), d=10.0.0.2 (Ethernet1), routed via FIB
*Mar  1 22:41:39.759: IP: s=10.0.0.1 (local), d=10.0.0.2 (Ethernet1), len 100, sending
*Mar  1 22:41:39.763:     ICMP type=8, code=0
*Mar  1 22:41:39.763: IP: tableid=1, s=10.0.0.2 (Ethernet1), d=10.0.0.1 (Ethernet1), routed via RIB
*Mar  1 22:41:39.763: IP: s=10.0.0.2 (Ethernet1), d=10.0.0.1 (Ethernet1), len 100, rcvd 3
*Mar  1 22:41:39.763:     ICMP type=0, code=0
*Mar  1 22:41:39.767: ICMP: echo reply rcvd, src 10.0.0.2, dst 10.0.0.1
*Mar  1 22:41:39.767: IP: tableid=1, s=10.0.0.1 (local), d=10.0.0.2 (Ethernet1), routed via FIB
*Mar  1 22:41:39.767: IP: s=10.0.0.1 (local), d=10.0.0.2 (Ethernet1), len 100, sending
*Mar  1 22:41:39.767:     ICMP type=8, code=0
*Mar  1 22:41:39.771: IP: tableid=1, s=10.0.0.2 (Ethernet1), d=10.0.0.1 (Ethernet1), routed via RIB
*Mar  1 22:41:39.771: IP: s=10.0.0.2 (Ethernet1), d=10.0.0.1 (Ethernet1), len 100, rcvd 3
*Mar  1 22:41:39.771:     ICMP type=0, code=0
*Mar  1 22:41:39.771: ICMP: echo reply rcvd, src 10.0.0.2, dst 10.0.0.1
*Mar  1 22:41:39.771: IP: tableid=1, s=10.0.0.1 (local), d=10.0.0.2 (Ethernet1), routed via FIB
*Mar  1 22:41:39.771: IP: s=10.0.0.1 (local), d=10.0.0.2 (Ethernet1), len 100, sending
*Mar  1 22:41:39.775:     ICMP type=8, code=0
*Mar  1 22:41:39.775: IP: tableid=1, s=10.0.0.2 (Ethernet1), d=10.0.0.1 (Ethernet1), routed via RIB
*Mar  1 22:41:39.775: IP: s=10.0.0.2 (Ethernet1), d=10.0.0.1 (Ethernet1), len 100, rcvd 3
*Mar  1 22:41:39.779:     ICMP type=0, code=0
*Mar  1 22:41:39.779: ICMP: echo reply rcvd, src 10.0.0.2, dst 10.0.0.1
*Mar  1 22:41:39.779: IP: tableid=1, s=10.0.0.1 (local), d=10.0.0.2 (Ethernet1), routed via FIB
*Mar  1 22:41:39.779: IP: s=10.0.0.1 (local), d=10.0.0.2 (Ethernet1), len 100, sending
*Mar  1 22:41:39.779:     ICMP type=8, code=0
*Mar  1 22:41:39.783: IP: tableid=1, s=10.0.0.2 (Ethernet1), d=10.0.0.1 (Ethernet1), routed via RIB
*Mar  1 22:41:39.783: IP: s=10.0.0.2 (Ethernet1), d=10.0.0.1 (Ethernet1), len 100, rcvd 3
*Mar  1 22:41:39.783:     ICMP type=0, code=0
*Mar  1 22:41:39.783: ICMP: echo reply rcvd, src 10.0.0.2, dst 10.0.0.1
Router1#ping vrf 100 10.0.1.2 source eth 1
Sending 5, 100-byte ICMP Echos to 10.0.1.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/5/8 ms
Router1#
*Mar  1 22:41:55.223: IP: tableid=1, s=10.0.0.1 (local), d=10.0.1.2 (Ethernet1), routed via FIB
*Mar  1 22:41:55.227: IP: s=10.0.0.1 (local), d=10.0.1.2 (Ethernet1), len 100, sending
*Mar  1 22:41:55.227:     ICMP type=8, code=0
*Mar  1 22:41:55.227: IP: tableid=1, s=10.0.1.2 (Ethernet1), d=10.0.0.1 (Ethernet1), routed via RIB
*Mar  1 22:41:55.227: IP: s=10.0.1.2 (Ethernet1), d=10.0.0.1 (Ethernet1), len 100, rcvd 3
*Mar  1 22:41:55.231:     ICMP type=0, code=0
*Mar  1 22:41:55.231: ICMP: echo reply rcvd, src 10.0.1.2, dst 10.0.0.1
*Mar  1 22:41:55.231: IP: tableid=1, s=10.0.0.1 (local), d=10.0.1.2 (Ethernet1), routed via FIB
*Mar  1 22:41:55.231: IP: s=10.0.0.1 (local), d=10.0.1.2 (Ethernet1), len 100, sending
*Mar  1 22:41:55.231:     ICMP type=8, code=0
*Mar  1 22:41:55.235: IP: tableid=1, s=10.0.1.2 (Ethernet1), d=10.0.0.1 (Ethernet1), routed via RIB
*Mar  1 22:41:55.235: IP: s=10.0.1.2 (Ethernet1), d=10.0.0.1 (Ethernet1), len 100, rcvd 3
*Mar  1 22:41:55.235:     ICMP type=0, code=0
*Mar  1 22:41:55.235: ICMP: echo reply rcvd, src 10.0.1.2, dst 10.0.0.1
*Mar  1 22:41:55.239: IP: tableid=1, s=10.0.0.1 (local), d=10.0.1.2 (Ethernet1), routed via FIB
*Mar  1 22:41:55.239: IP: s=10.0.0.1 (local), d=10.0.1.2 (Ethernet1), len 100, sending
*Mar  1 22:41:55.239:     ICMP type=8, code=0
*Mar  1 22:41:55.239: IP: tableid=1, s=10.0.1.2 (Ethernet1), d=10.0.0.1 (Ethernet1), routed via RIB
*Mar  1 22:41:55.243: IP: s=10.0.1.2 (Ethernet1), d=10.0.0.1 (Ethernet1), len 100, rcvd 3
*Mar  1 22:41:55.243:     ICMP type=0, code=0
*Mar  1 22:41:55.243: ICMP: echo reply rcvd, src 10.0.1.2, dst 10.0.0.1
*Mar  1 22:41:55.243: IP: tableid=1, s=10.0.0.1 (local), d=10.0.1.2 (Ethernet1), routed via FIB
*Mar  1 22:41:55.243: IP: s=10.0.0.1 (local), d=10.0.1.2 (Ethernet1), len 100, sending
*Mar  1 22:41:55.247:     ICMP type=8, code=0
*Mar  1 22:41:55.247: IP: tableid=1, s=10.0.1.2 (Ethernet1), d=10.0.0.1 (Ethernet1), routed via RIB
*Mar  1 22:41:55.247: IP: s=10.0.1.2 (Ethernet1), d=10.0.0.1 (Ethernet1), len 100, rcvd 3
*Mar  1 22:41:55.247:     ICMP type=0, code=0
*Mar  1 22:41:55.251: ICMP: echo reply rcvd, src 10.0.1.2, dst 10.0.0.1
*Mar  1 22:41:55.251: IP: tableid=1, s=10.0.0.1 (local), d=10.0.1.2 (Ethernet1), routed via FIB
*Mar  1 22:41:55.251: IP: s=10.0.0.1 (local), d=10.0.1.2 (Ethernet1), len 100, sending
*Mar  1 22:41:55.251:     ICMP type=8, code=0
*Mar  1 22:41:55.255: IP: tableid=1, s=10.0.1.2 (Ethernet1), d=10.0.0.1 (Ethernet1), routed via RIB
*Mar  1 22:41:55.255: IP: s=10.0.1.2 (Ethernet1), d=10.0.0.1 (Ethernet1), len 100, rcvd 3
*Mar  1 22:41:55.255:     ICMP type=0, code=0
*Mar  1 22:41:55.255: ICMP: echo reply rcvd, src 10.0.1.2, dst 10.0.0.1
Router1#ping vrf 100 10.0.1.1 source eth 1
Sending 5, 100-byte ICMP Echos to 10.0.1.1, timeout is 2 seconds:
*Mar  1 22:42:14.775: IP: tableid=1, s=10.0.0.1 (local), d=10.0.1.1 (Ethernet1), routed via FIB
*Mar  1 22:42:14.775: IP: s=10.0.0.1 (local), d=10.0.1.1 (Ethernet1), len 100, sending
*Mar  1 22:42:14.775:     ICMP type=8, code=0.
*Mar  1 22:42:16.771: IP: tableid=1, s=10.0.0.1 (local), d=10.0.1.1 (Ethernet1), routed via FIB
*Mar  1 22:42:16.771: IP: s=10.0.0.1 (local), d=10.0.1.1 (Ethernet1), len 100, sending
*Mar  1 22:42:16.771:     ICMP type=8, code=0.
*Mar  1 22:42:18.771: IP: tableid=1, s=10.0.0.1 (local), d=10.0.1.1 (Ethernet1), routed via FIB
*Mar  1 22:42:18.771: IP: s=10.0.0.1 (local), d=10.0.1.1 (Ethernet1), len 100, sending
*Mar  1 22:42:18.771:     ICMP type=8, code=0.
*Mar  1 22:42:20.771: IP: tableid=1, s=10.0.0.1 (local), d=10.0.1.1 (Ethernet1), routed via FIB
*Mar  1 22:42:20.771: IP: s=10.0.0.1 (local), d=10.0.1.1 (Ethernet1), len 100, sending
*Mar  1 22:42:20.771:     ICMP type=8, code=0.
*Mar  1 22:42:22.771: IP: tableid=1, s=10.0.0.1 (local), d=10.0.1.1 (Ethernet1), routed via FIB
*Mar  1 22:42:22.771: IP: s=10.0.0.1 (local), d=10.0.1.1 (Ethernet1), len 100, sending
*Mar  1 22:42:22.771:     ICMP type=8, code=0.
Success rate is 0 percent (0/5)
Router1#
Seems like there is no reply from R3, but routing table is correct on R3.
Any ideas???
zdesve33 Wed, 07/21/2010 - 01:22
I guess you try e.g. traceroute - what was result? Did you have turned on debug on r3 if you tried to ping from r1 (and vice versa)? Are there any incoming on the other side? If not, lets make focus on r2 (turn off cef, torn on debug ip packet).
Marcus Johansson Wed, 07/21/2010 - 02:21
Solved, R2 was behaving strange, disabled routing & enabled it again and rebooted. Now it works.
Thanks everybody.
zdesve33 Wed, 07/21/2010 - 02:27
... did you try switch it off and on ?... Nice excercising in troubleshooting :-))
Marcus Johansson Wed, 07/21/2010 - 00:43
Ping results from R3 to R2 and R1
Router3#ping vrf 100 10.0.1.2 source eth1
Packet sent with a source address of 10.0.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/6/8 ms
Router3#
*Mar  1 18:56:34.911: IP: tableid=1, s=10.0.1.1 (local), d=10.0.1.2 (Ethernet1), routed via FIB
*Mar  1 18:56:34.911: IP: s=10.0.1.1 (local), d=10.0.1.2 (Ethernet1), len 100, sending
*Mar  1 18:56:34.911:     ICMP type=8, code=0
*Mar  1 18:56:34.915: IP: tableid=1, s=10.0.1.2 (Ethernet1), d=10.0.1.1 (Ethernet1), routed via RIB
*Mar  1 18:56:34.915: IP: s=10.0.1.2 (Ethernet1), d=10.0.1.1 (Ethernet1), len 100, rcvd 3
*Mar  1 18:56:34.915:     ICMP type=0, code=0
*Mar  1 18:56:34.915: ICMP: echo reply rcvd, src 10.0.1.2, dst 10.0.1.1
*Mar  1 18:56:34.915: IP: tableid=1, s=10.0.1.1 (local), d=10.0.1.2 (Ethernet1), routed via FIB
*Mar  1 18:56:34.919: IP: s=10.0.1.1 (local), d=10.0.1.2 (Ethernet1), len 100, sending
*Mar  1 18:56:34.919:     ICMP type=8, code=0
*Mar  1 18:56:34.919: IP: tableid=1, s=10.0.1.2 (Ethernet1), d=10.0.1.1 (Ethernet1), routed via RIB
*Mar  1 18:56:34.923: IP: s=10.0.1.2 (Ethernet1), d=10.0.1.1 (Ethernet1), len 100, rcvd 3
*Mar  1 18:56:34.923:     ICMP type=0, code=0
*Mar  1 18:56:34.923: ICMP: echo reply rcvd, src 10.0.1.2, dst 10.0.1.1
*Mar  1 18:56:34.923: IP: tableid=1, s=10.0.1.1 (local), d=10.0.1.2 (Ethernet1), routed via FIB
*Mar  1 18:56:34.923: IP: s=10.0.1.1 (local), d=10.0.1.2 (Ethernet1), len 100, sending
*Mar  1 18:56:34.923:     ICMP type=8, code=0
*Mar  1 18:56:34.927: IP: tableid=1, s=10.0.1.2 (Ethernet1), d=10.0.1.1 (Ethernet1), routed via RIB
*Mar  1 18:56:34.927: IP: s=10.0.1.2 (Ethernet1), d=10.0.1.1 (Ethernet1), len 100, rcvd 3
*Mar  1 18:56:34.927:     ICMP type=0, code=0
*Mar  1 18:56:34.927: ICMP: echo reply rcvd, src 10.0.1.2, dst 10.0.1.1
*Mar  1 18:56:34.931: IP: tableid=1, s=10.0.1.1 (local), d=10.0.1.2 (Ethernet1), routed via FIB
*Mar  1 18:56:34.931: IP: s=10.0.1.1 (local), d=10.0.1.2 (Ethernet1), len 100, sending
*Mar  1 18:56:34.931:     ICMP type=8, code=0
*Mar  1 18:56:34.935: IP: tableid=1, s=10.0.1.2 (Ethernet1), d=10.0.1.1 (Ethernet1), routed via RIB
*Mar  1 18:56:34.935: IP: s=10.0.1.2 (Ethernet1), d=10.0.1.1 (Ethernet1), len 100, rcvd 3
*Mar  1 18:56:34.935:     ICMP type=0, code=0
*Mar  1 18:56:34.935: ICMP: echo reply rcvd, src 10.0.1.2, dst 10.0.1.1
*Mar  1 18:56:34.935: IP: tableid=1, s=10.0.1.1 (local), d=10.0.1.2 (Ethernet1), routed via FIB
*Mar  1 18:56:34.935: IP: s=10.0.1.1 (local), d=10.0.1.2 (Ethernet1), len 100, sending
*Mar  1 18:56:34.939:     ICMP type=8, code=0
*Mar  1 18:56:34.939: IP: tableid=1, s=10.0.1.2 (Ethernet1), d=10.0.1.1 (Ethernet1), routed via RIB
*Mar  1 18:56:34.939: IP: s=10.0.1.2 (Ethernet1), d=10.0.1.1 (Ethernet1), len 100, rcvd 3
*Mar  1 18:56:34.943:     ICMP type=0, code=0
*Mar  1 18:56:34.943: ICMP: echo reply rcvd, src 10.0.1.2, dst 10.0.1.1
Router3#ping vrf 100 10.0.0.2 source eth1
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/9/24 ms
Router3#
*Mar  1 18:56:51.155: IP: tableid=1, s=10.0.1.1 (local), d=10.0.0.2 (Ethernet1), routed via FIB
*Mar  1 18:56:51.155: IP: s=10.0.1.1 (local), d=10.0.0.2 (Ethernet1), len 100, sending
*Mar  1 18:56:51.155:     ICMP type=8, code=0
*Mar  1 18:56:51.159: IP: tableid=1, s=10.0.0.2 (Ethernet1), d=10.0.1.1 (Ethernet1), routed via RIB
*Mar  1 18:56:51.159: IP: s=10.0.0.2 (Ethernet1), d=10.0.1.1 (Ethernet1), len 100, rcvd 3
*Mar  1 18:56:51.159:     ICMP type=0, code=0
*Mar  1 18:56:51.163: ICMP: echo reply rcvd, src 10.0.0.2, dst 10.0.1.1
*Mar  1 18:56:51.163: IP: tableid=1, s=10.0.1.1 (local), d=10.0.0.2 (Ethernet1), routed via FIB
*Mar  1 18:56:51.163: IP: s=10.0.1.1 (local), d=10.0.0.2 (Ethernet1), len 100, sending
*Mar  1 18:56:51.163:     ICMP type=8, code=0
*Mar  1 18:56:51.183: IP: tableid=1, s=10.0.0.2 (Ethernet1), d=10.0.1.1 (Ethernet1), routed via RIB
*Mar  1 18:56:51.183: IP: s=10.0.0.2 (Ethernet1), d=10.0.1.1 (Ethernet1), len 100, rcvd 3
*Mar  1 18:56:51.183:     ICMP type=0, code=0
*Mar  1 18:56:51.183: ICMP: echo reply rcvd, src 10.0.0.2, dst 10.0.1.1
*Mar  1 18:56:51.187: IP: tableid=1, s=10.0.1.1 (local), d=10.0.0.2 (Ethernet1), routed via FIB
*Mar  1 18:56:51.187: IP: s=10.0.1.1 (local), d=10.0.0.2 (Ethernet1), len 100, sending
*Mar  1 18:56:51.187:     ICMP type=8, code=0
*Mar  1 18:56:51.191: IP: tableid=1, s=10.0.0.2 (Ethernet1), d=10.0.1.1 (Ethernet1), routed via RIB
*Mar  1 18:56:51.191: IP: s=10.0.0.2 (Ethernet1), d=10.0.1.1 (Ethernet1), len 100, rcvd 3
*Mar  1 18:56:51.191:     ICMP type=0, code=0
*Mar  1 18:56:51.191: ICMP: echo reply rcvd, src 10.0.0.2, dst 10.0.1.1
*Mar  1 18:56:51.191: IP: tableid=1, s=10.0.1.1 (local), d=10.0.0.2 (Ethernet1), routed via FIB
*Mar  1 18:56:51.191: IP: s=10.0.1.1 (local), d=10.0.0.2 (Ethernet1), len 100, sending
*Mar  1 18:56:51.195:     ICMP type=8, code=0
*Mar  1 18:56:51.195: IP: tableid=1, s=10.0.0.2 (Ethernet1), d=10.0.1.1 (Ethernet1), routed via RIB
*Mar  1 18:56:51.195: IP: s=10.0.0.2 (Ethernet1), d=10.0.1.1 (Ethernet1), len 100, rcvd 3
*Mar  1 18:56:51.199:     ICMP type=0, code=0
*Mar  1 18:56:51.199: ICMP: echo reply rcvd, src 10.0.0.2, dst 10.0.1.1
*Mar  1 18:56:51.199: IP: tableid=1, s=10.0.1.1 (local), d=10.0.0.2 (Ethernet1), routed via FIB
*Mar  1 18:56:51.199: IP: s=10.0.1.1 (local), d=10.0.0.2 (Ethernet1), len 100, sending
*Mar  1 18:56:51.199:     ICMP type=8, code=0
*Mar  1 18:56:51.203: IP: tableid=1, s=10.0.0.2 (Ethernet1), d=10.0.1.1 (Ethernet1), routed via RIB
*Mar  1 18:56:51.203: IP: s=10.0.0.2 (Ethernet1), d=10.0.1.1 (Ethernet1), len 100, rcvd 3
*Mar  1 18:56:51.203:     ICMP type=0, code=0
*Mar  1 18:56:51.203: ICMP: echo reply rcvd, src 10.0.0.2, dst 10.0.1.1
Router3#ping vrf 100 10.0.0.1 source eth1
Sending 5, 100-byte ICMP Echos to 10.0.0.1, timeout is 2 seconds:
*Mar  1 18:57:05.295: IP: tableid=1, s=10.0.1.1 (local), d=10.0.0.1 (Ethernet1), routed via FIB
*Mar  1 18:57:05.295: IP: s=10.0.1.1 (local), d=10.0.0.1 (Ethernet1), len 100, sending
*Mar  1 18:57:05.295:     ICMP type=8, code=0.
*Mar  1 18:57:07.295: IP: tableid=1, s=10.0.1.1 (local), d=10.0.0.1 (Ethernet1), routed via FIB
*Mar  1 18:57:07.295: IP: s=10.0.1.1 (local), d=10.0.0.1 (Ethernet1), len 100, sending
*Mar  1 18:57:07.295:     ICMP type=8, code=0.
*Mar  1 18:57:09.295: IP: tableid=1, s=10.0.1.1 (local), d=10.0.0.1 (Ethernet1), routed via FIB
*Mar  1 18:57:09.295: IP: s=10.0.1.1 (local), d=10.0.0.1 (Ethernet1), len 100, sending
*Mar  1 18:57:09.295:     ICMP type=8, code=0.
*Mar  1 18:57:11.295: IP: tableid=1, s=10.0.1.1 (local), d=10.0.0.1 (Ethernet1), routed via FIB
*Mar  1 18:57:11.295: IP: s=10.0.1.1 (local), d=10.0.0.1 (Ethernet1), len 100, sending
*Mar  1 18:57:11.295:     ICMP type=8, code=0.
*Mar  1 18:57:13.295: IP: tableid=1, s=10.0.1.1 (local), d=10.0.0.1 (Ethernet1), routed via FIB
*Mar  1 18:57:13.295: IP: s=10.0.1.1 (local), d=10.0.0.1 (Ethernet1), len 100, sending
*Mar  1 18:57:13.295:     ICMP type=8, code=0.
Router3#
