webvpn portal on asa8.0(4):group-url
Answered Question
Jul 20th, 2010
Hi all,
I have a problem when I try to use group-list command to select directly the group for an ssl vpn without the drop-down list.
I enable the command group-url  https://a.a.a.a:port/test in the Tunnel-group but even if I put it in my browser I always
see the drop-down list.
This happens with an ASA8.0(4).
I have an ASA8.2(1) and I don't have this problem.
I noted this difference in the url of the login page after redirection:
8.0(4)  https://a.a.a.a:port/+CSCOE+/logon.html?token=4D6912AB72A1FCFA2643F325
8.2(1)  https://a.a.a.a:port/+CSCOE+/logon.html?tg=test&token=4D6912AB72A1FCFA2643F325
Can anyone make any auggestion?
Thank you in advance!
Correct Answer by Todd Pula about 6 years 10 months ago
There are a few bugs related to group-urls in 8.0.4.  In your test above, what port have you configured the ASA to listen on for WebVPN connections?  If something other than port 443, you may be running in to bug CSCsu77167.
Overall Rating: 5 (1 ratings)
Correct Answer
Todd Pula Tue, 07/20/2010 - 14:39
  • Silver, 250 points or more
gdspa Wed, 07/21/2010 - 00:10
On the asa with 8.0(4) the listen port is not the 443.
Thank you very much Todd! I will try to upgrade.
