physical mac Vs virtual mac
Answered Question
Jul 20th, 2010
hey i want to know that what is the difference between physical mac and virtual mac?where we use physical n where we use virtual?can we change our device physical mac?is possible then how?
Correct Answer by Nagaraja Thanthry about 6 years 11 months ago
Physical MAC addresses are the burned-in addresses on the hardware. Typically, this is bound by the IANA rules and each vendor will have a specific range that they can use.
Virtual MAC addresses are user configurable parameter that people use in the network for simplicity sake. Virtual MACs are used typically when you have a redundancy setup where all the redundant components will share the same virtual MAC. So, the network need to forward only one copy of the datagram to the virtual MAC and all corresponding components will process it.
Typical examples of use of virtual MAC:
HSRP setup
Server Load Balancing
Firewall Failovers
Hope this helps.
NT
Overall Rating: 5 (1 ratings)
Correct Answer
Nagaraja Thanthry Tue, 07/20/2010 - 09:10
  • Cisco Employee,
HSRP setup
Firewall Failovers
Hope this helps.
NT
