IPCC EXPRESS LICENSE
Answered Question
Jul 20th, 2010
     Hi, I have a question about licensing on ipcc express enhanced.
I need to configure some work flow actions over supervisor desktop software, message box action and audible alert action, because the only available is tree control action, it is a licence problem? shoul i have premium license?
Is there a document for diferences between premium and enhanced?
Regards and thanks for your time.
Carlos
Correct Answer by Jonathan Schulenberg about 6 years 6 months ago
Yes you need a premium license. The only work flow action enabled in enhanced is tree control.
As for documentation: A quick glance at the Cisco Supervisor Desktop User Guide for CAD 6.6 for  Unified CM showed this statement on page 56. It may also be listed elsewhere.
NOTE:  Supervisor work flow actions are available at the Premium
feature level, except for the Tree Control action, which is also
available at the Enhanced feature level.
Overall Rating: 5 (1 ratings)
Correct Answer
Jonathan Schulenberg Tue, 07/20/2010 - 10:49
