AP 1310 stuck in bridge: mode. cant assign IP
I have a 1310
its in bridge: mode after i lost the password and deleted all files from it per some pw recovery link i saw.
i assigned an IP, SM, DR and the device isnt accessible to be pinged etc. Step 6 just times out.
(see https://supportforums.cisco.com/docs/DOC-8091)
Step 6 Enter the tar command to load and inflate the new image from your TFTP server. The command must include this information:
tar -xtract tftp://192.168.130.222/images/c350-k9w7-tar.122-13.JA1.tar flash:
the lights are red, yellow, red and orange (left to right top to bottom).
also when i do this i get that:
bridge: dir flash0
unable to stat flash0/: permission denied
Overall Rating: 4 (1 ratings)
dancampb Tue, 07/20/2010 - 11:59
  • Cisco Employee,
If you are getting permission denied to the flash it sounds like you need to initilize the flash.
ap:flash_init
After you init the flash then see if you can do a dir and see the flash.  You may need to init tftp too.
hi Dan
i tried and its still the same but i see now different commands yield different results.
bridge: flash_init
Initializing F..The flash is aized.
bridge: dir
List of filesystems currently registered:
               flash[0]: (read-write)
              xmodem[1]: (read-only)
                null[2]: (read-write)
                td-only)
bridge: dir flash:
Directory of flash:/
3    -rwx  73                       env_vars
7739904 bytes available (1536 bytes used)
bridge: dir flash0
my main problem still stands - i cant get the IP to "take", after setting the 3 values i cant ping the 1310.
i ran all init commands did a reset too.
the LED's changed. now i only have a green on the S.
which is better then what i had before...
dancampb Tue, 07/20/2010 - 12:15
  • Cisco Employee,
OK, so the flash would now be available to take the image.
Can you post the output of what you are typing to set the IP info?  The commands are case sensitive but should work.
dancampb Tue, 07/20/2010 - 12:38
  • Cisco Employee,
Those commands look right, did you try doing an ether_init?
i ran the etest series and i think theres a HW problem?
bridge:  etest 7
transmitting test, see if we can send packet
[Packet Transmit: port 0]
        sending 1200 bytes:
    0080 00a0 1032 0014 69f9 3584 1234 1235
    1236 1237 1238 1239 123a 123b 123c 123d
etest_sendpkt: ERROR: packet 1ecef08 sent failed
        etest_sendpkt() failed.
        sending 1200 bytes:
    0080 00a0 1032 0014 69f9 3584 04b0 1235
-- MORE --
        sending 1200 bytes:
        sending 1200 bytes:
        sending 1200 bytes:
-- MORE --
        sending 1200 bytes:
        sending 1200 bytes:
        sending 1200 bytes:
-- MORE --
        sending 1200 bytes:
        sending 1200 bytes:
-- MORE --
transmit: completed.
                        RECEIVED                           SENT
good frame bytes :          0                                   0
good frames      :          0                                   0
broadcast frames :          0                                   0
multicast frames :          0                                   0
dropped frames   :          0                                   0
pause frames     :          0                                   0
error frames     :          0                                   0
CRC error frames :          0                                   0
overrun frames   :          0   underrun frames      :          0
runt frames      :          0   deferred frames      :          0
in range errors  :          0   single collisions    :          0
out range errors :          0   multiple collisions  :          0
align errors     :          0   late collisions      :          0
-- MORE --
short event      :          0   excessive collisions :          0
too long frames  :          0   carrier sense errors :          0
bad frames       :          0   bad previous frames  :          0
                                signal quality errors:          0
        Total Tx/Rx bytes:           0
other errors:
        Total MAL rx sys error          0
        Total MAL tx sys error          0
        Total MAL rx de error           0
        Total MAL tx de error           0
        Total MAL EMAC  error           0
