SR-520 locks up using Trend Micro
Jul 20th, 2010
I have not had a lot of luck using Trend Micro with the SR520 routers.  The current problem I am having is when someone accesses a website the SR520 locks up and I cant talk to the internet I can talk to it locally only.  After a long time of troubleshooting I found out that it is with the Trend Micro integration.  I have removed it and the problem completely stopped. I have removed and replaced the configuration but I am missing something.  My best guess is that the website is permitted but something on the website is not and I certainly could be wrong.  I noticed that blog websites cause this problem alot.  Anything on does this too.  I have included the running configuration as well as the "sho version".   Thanks in advance!
Panos Kampanakis Wed, 07/21/2010 - 10:37
Can you check why packets are not flowing? Logs should tell you if packets are dropped.
Also is it only http that has issues or all traffic. It could be ZBF related. For example fo pings flow fine when the router is "locked up"?
Related Content
