nseto Wed, 07/21/2010 - 16:31
  • Silver, 250 points or more
Can you put down the parameter name that you are looking at?   We have 'debug level'  which range from 0 to 3, is that what you are looking for?
JoshFoshee Wed, 07/21/2010 - 16:41
Yes on syslog you have syslog UNIX facilities that it can use. The SPA-942 sends out on local0 by default. I was wanting to change to a different local. The local options are local0 through local7. You can change them in a cisco router by "Logging Facility localX" command. A further example can be found here for the 12.0 firmware on Cisco routers. http://www.cisco.com/en/US/docs/ios/12_0/configfun/configuration/guide/fctroubl.html#wp5170. Hope this clarifies the setting I am trying to change.
Josh
nseto Wed, 07/21/2010 - 17:13
The only thing that we can append to the ip address is the port number for the syslog or debug server parameters.  For example, you can put in 192.168.2.2:515 for those parameters to write to that ip address and port 515.  By default, if you just have the ip address, it will write to port 514.
Related Content
