UCM 7.1 Phone Cluster Move
Jul 20th, 2010
Is it possible to take phones from one of our clusters and move them to another? I have a 7.1 cluster in Manchester, a 6.1 cluster in Sydney, and a 7.1 cluster in the US. I would like to take some extra phones from the US and send them to both sites. Is this possible with the way licensing works with these versions of CM? Thanks.
Adrian Saavedra Tue, 07/20/2010 - 22:19
No problem. You can take phones from US and register them in Manchester and Sydney, as long as these clusters have available DLUs (device license units).
Hope it helps, please rate if it does.
Kind regards,
- Adrian.
anthonymd Wed, 07/21/2010 - 14:20
Thank you for the quick response Adrian. I guess what I was asking if there is a way to move the licenses with the phones. We don't have
any "spare" licenses at either site. I guess I can just have them buy licenses for these types of phones
then just not have to purchase licenses if I buy more for the US.
Jaime Valencia Wed, 07/21/2010 - 14:46
You would need to get in touch with the licensing team.
There is no easy way to take the DLUs with the phone.
They would need to substract those DLUs from your current pool and then create a new lic file with the MAC from the licensing server of the other cluster for the necessary DLUs for the phone(s).
The only other option would be as you mention, buy more DLUs.
If this helps, please rate
