getting EMC SMARTS to recognise CISCO-EPM-NOTIFICATION-MIB traps
Jul 21st, 2010
Has anyone found a way of getting EMC SMARTS to recognise CISCO-EPM-NOTIFICATION-MIB traps (As sent by CiscoWorks etc.)?  In particular I'm interested in getting it to recognize the Active and Clear states.
GERARD PUOPLO Thu, 07/22/2010 - 07:20
INCHARGE-OI needs to be configured to get traps from the Trap-Adapter.  I believe in the out of box trap_mgr.conf file this trap is already defined. If not configured it as follows or something similar.
So just enable the trap adapter and configure the notification list so you filter out all the trap events you don't care about.
# Cisco EPM Notification MIB Trap
#    The following trap definition is to accept traps from
#    an IP Telephony Monitor (ITM) Device. By Default this
#    defintion  assumes  the  device  is available in Open
#    Integration Server's  topology. If Not, then the this
#    trap will be ignored ( because of UnknownAgent=IGNORE)
BEGIN_TRAP .1.3.6.1.4.1.9.9.311.0.1 6 1
       ClassName:   SNMPTrap
       InstanceName:       $SYS$
       EventName:   ciscoEpmNotificationAlarm
       Severity:    3
       EventText:   The 22 Varibles are - cenAlarmVersion= $V1$  cenAlarmTimestamp= $V2$  cenAlarmUpdatedTimestamp= $V3$  cenAlarmInstanceID= $V4$  cenAlarmStatus= $V5$  cenAlarmStatusDefinition= $V6$  cenAlarmType= $V7$  cenAlarmCategory= $V8$  cenAlarmCategoryDefinition= $V9$  cenAlarmServerAddressType= $V10$  cenAlarmServerAddress= $V11$  cenAlarmManagedObjectClass= $V12$  cenAlarmManagedObjectAddressType= $V13$  cenAlarmManagedObjectAddress= $V14$  cenAlarmDescription= $V15$  cenAlarmSeverity= $V16$  cenAlarmSeverityDefinition= $V17$  cenAlarmTriageValue= $V18$  cenEventIDList= $V19$  cenUserMessage1= $V20$  cenUserMessage2= $V21$  cenUserMessage3= $V22$
       Expiration:  600
       State:         NOTIFY
        UnknownAgent:   IGNORE
        LogFile:        NONE
END_TRAP
steve_evitts Thu, 07/22/2010 - 08:07
Hi Gerard
We've actually gone one step further with these traps already, see an extract from the conf bellow:
# Configured EPM Traps below
BEGIN_TRAP .1.3.6.1.4.1.9.9.311 6 1
ClassName: SNMPTrap
InstanceName: $V14$
EventName: Voice_Environment
Severity: 3
EventText: $V15$
State:         NOTIFY
        UnknownAgent:   CREATE
        UserDefined9:   The 22 Variables are - cenAlarmVersion= $V1$  cenAlarmTimestamp= $V2$  cenAlarmUpdatedTimestamp= $V3$  cenAlarmInstanceID= $V4$  cenAlarmStatus= $V5$  cenAlarmStatusDefinition= $V6$  cenAlarmType= $V7$  cenAlarmCategory= $V8$  cenAlarmCategoryDefinition= $V9$  cenAlarmServerAddressType= $V10$  cenAlarmServerAddress= $V11$  cenAlarmManagedObjectClass= $V12$  cenAlarmManagedObjectAddressType= $V13$  cenAlarmManagedObjectAddress= $V14$  cenAlarmDescription= $V15$  cenAlarmSeverity= $V16$  cenAlarmSeverityDefinition= $V17$  cenAlarmTriageValue= $V18$  cenEventIDList= $V19$  cenUserMessage1= $V20$  cenUserMessage2= $V21$  cenUserMessage3= $V22$
        UserDefined10:  $E$ $N$ $S$
END_TRAP
BEGIN_TRAP .1.3.6.1.4.1.9.9.311 6 2
ClassName: SNMPTrap
InstanceName: $V14$
Severity: 3
EventText: $V15$
State:         NOTIFY
END_TRAP
The problem is that these are both still "State: NOTIFY" as is the config you sent.
I think perhaps what we need is an ASL script that will pull out $V16$ (cenAlarmSeverity") and decide if that trap is a "NOTIFY" or a "CLEAR".
Right now, we see the traps in SMARTS...but it is not able to tell the difference between notify and clear traps.
Steve
Related Content
