IPsec Tunnel PIX issues
Can anyone provide me soln for the below
My goal is to create an ipsec tunnel between my pix and fortigate(other vendor)
I am facing a lot of issues
Site A network looks like this
---10.41.x.x/16---switch(192.168.1.1/30)----(192.168.1.2)pix--122.x.x.x----internet
Site B look like this
10.x.x.x/8----fortigate---116.x.x.x---internet
Before establishing tunnel i tried to ping the pix outside address from my fortigate and pinging fine
{As public ip its fine and reachable}
But after i create ipsec tunnel from fortigate its not pinging my pix firewall outside ip! what might be the issue? and its not even pinging directly connected gateway ip
one more i need to know is while creating cryptomap on pix,which network i have to define
192.168.x.x or 10.41.x.x ?
Do i need to create any static route ? for internal subnet reachability? if so how ?
can some one explain in detail to address these issues ?
Seeking help from experts
Pramod
Rahul Govindan Wed, 07/21/2010 - 04:37
  • Silver, 250 points or more
The interesting traffic should be between your 10.41.x.x on site A and the 10.x.x.x on site B( if those indeed are your networks). Is that what has been defined on the PIX and fortigate?
Also th route to be added on the PIX should be
route inside 10.41.x.x 255.255.0.0 192.168.1.1
Jennifer Halim Wed, 07/21/2010 - 14:15
  • Cisco Employee,
You would need to create mirror image crypto ACL on the PIX and Fortigate.
Based on the network diagram, I assume that from the PIX end, your traffic would be from 10.41.0.0/16, hence that would be the interesting traffic for your crypto ACL.
However, looks like you have overlapping networks between your Fortigate LAN and PIX LAN as both falls under the 10.0.0.0 network. If your Fortigate LAN /8? If it is, then it's overlapping. You would need to NAT the traffic so it's not overlapping because routing will not work when it's overlapping subnets. If your Fortigate LAN is /24, then it's OK.
Here is a sample configuration for overlapping subnet for your reference:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080b37d0b.shtml
Hope that helps.
