nat transparency and %CRYPTO-4-RECVD_PKT_INV_SPI
Hello!
I need to establish vpn connection over internet.
On one side I have cisco 3845 which is directly connected to internet.
On another side I have 2801, which is behind zyxel adsl modem in router mode (i.e. real ip is on modem, modem do nat for cisco).
sh crypto sess on 2801:
Interface: FastEthernet0/0
Session status: UP-ACTIVE
Peer: 78.85.33.237 port 4500
  IKE SA: local 192.168.107.1/4500 remote 78.85.133.237/4500 Active
  IPSEC FLOW: permit 47 0.0.0.0/0.0.0.0 host 78.85.133.237
        Active SAs: 6, origin: crypto map
sh crypto sess on 3845:
Interface: Serial3/0.200
Peer: 78.85.37.90 port 10017
  IKE SA: local 78.85.133.237/4500 remote 78.85.137.90/10017 Active
  IPSEC FLOW: permit 47 host 78.85.133.237 0.0.0.0/0.0.0.0
But traffic doesn't pass.
I see the same error on both sides:
%CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=192.168.107.1, prot=17, spi=0x32040000(839122944), srcaddr=78.85.133.237
NAT-T is on:
crypto ipsec nat-transparency udp-encapsulation
Could you tell me how can I solve this problem?
Jennifer Halim Wed, 07/21/2010 - 14:18
Are you configuring GRE over IPsec tunnel?
Can you share the output of the following from both devices:
show cry isa sa
show cry ipsec sa
Hello!
Yes, I use GRE over ipsec.
I changed configuration, just because I use 3845 in production and it is not easy to run debugs on it.
So now configuration is following:
2801-pix515--internet-zyxel adsl modem-2801.
2801 config on left side:
crypto isakmp KEY address A.85.37.90
crypto ipsec transform-set mpr-vtk ah-sha-hmac esp-aes 256 comp-lzs
crypto map mpr-vtk-map 10 ipsec-isakmp
set peer B.85.37.90
set transform-set mpr-vtk
match address 112
access-list 112 permit gre any any
interface Tunnel0
  ip address 192.168.200.102 255.255.255.252
tunnel source FastEthernet0/0
tunnel destination B.85.37.90
2801 on right side:
crypto isakmp key MPRmPr address A.80.32.213
  set peer A.80.32.213
match address 112
interface Tunnel1
ip address 192.168.200.101 255.255.255.252
tunnel destination B.85.33.237
output, left 2801:
show cry isa sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
B.85.37.90     192.168.22.22   QM_IDLE           1003 ACTIVE
show cry ipsec sa
interface: FastEthernet0/0
    Crypto map tag: mpr-vtk-map, local addr 192.168.22.22
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/47/0)
   remote ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/47/0)
   current_peer 78.85.37.90 port 4500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 24, #pkts encrypt: 24, #pkts digest: 24
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 24, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 1, #recv errors 0
     local crypto endpt.: 192.168.22.22, remote crypto endpt.: B.85.37.90
     path mtu 1500, ip mtu 1500, ip mtu idb FastEthernet0/0
     current outbound spi: 0x35BD59A1(901601697)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
      spi: 0x4D6FFB0E(1299184398)
        transform: esp-256-aes ,
        in use settings ={Tunnel UDP-Encaps, }
        conn id: 2001, flow_id: FPGA:1, sibling_flags 80000076, crypto map: mpr-vtk-map
        sa timing: remaining key lifetime (k/sec): (4487476/2411)
        IV size: 16 bytes
        replay detection support: Y
        Status: ACTIVE
     inbound ah sas:
      spi: 0xFDF4294A(4260637002)
        transform: ah-sha-hmac ,
        Status: ACTIVE
     inbound pcp sas:
      spi: 0xD249(53833)
        transform: comp-lzs ,
        Status: ACTIVE
     outbound esp sas:
        conn id: 2002, flow_id: FPGA:2, sibling_flags 80000076, crypto map: mpr-vtk-map
        sa timing: remaining key lifetime (k/sec): (4487471/2411)
        IV size: 16 bytes
        Status: ACTIVE
     outbound ah sas:
      spi: 0xFC573A77(4233575031)
        Status: ACTIVE
     outbound pcp sas:
      spi: 0x7882(30850)
        Status: ACTIVE
right 2801:
show cry isa sa
dst             src             state          conn-id slot status
192.168.107.1   A.80.32.213    QM_IDLE              9    0 ACTIVE
    Crypto map tag: mpr-vtk-map, local addr 192.168.107.1
   current_peer 88.80.32.213 port 4500
    #pkts encaps: 5, #pkts encrypt: 5, #pkts digest: 5
    #pkts not compressed: 5, #pkts compr. failed: 0
    #send errors 0, #recv errors 0
     local crypto endpt.: 192.168.107.1, remote crypto endpt.: A.80.32.213
     current outbound spi: 0x4D6FFB0E(1299184398)
     inbound esp sas:
        conn id: 3004, flow_id: FPGA:4, crypto map: mpr-vtk-map
        sa timing: remaining key lifetime (k/sec): (4579927/2253)
        IV size: 16 bytes
        Status: ACTIVE
     inbound ah sas:
        Status: ACTIVE
     inbound pcp sas:
      spi: 0x7882(30850)
        Status: ACTIVE
     outbound esp sas:
        conn id: 3003, flow_id: FPGA:3, crypto map: mpr-vtk-map
        sa timing: remaining key lifetime (k/sec): (4579926/2253)
        IV size: 16 bytes
        Status: ACTIVE
     outbound ah sas:
        Status: ACTIVE
     outbound pcp sas:
      spi: 0xD249(53833)
        sa timing: remaining key lifetime (k/sec): (4579926/2252)
        Status: ACTIVE
Thank you!
mireynol Fri, 07/23/2010 - 13:26
First off since behind a NAT, can you configure your transform set to "mode transport"?  Do this on both sides and clear the tunnels and see if the behavior changes.
config t
mode transport
I have also seen some issues with using ah and esp, but if memory serves me right it didn't affect these platforms.
