ACS 5.0
Jul 21st, 2010
I have just installed the ACS 1120 appliance with ACS 5.0. It was working fine for about a week. Now however I am getting the following error message when I try to start monitoring: The monitoring and reports database is currently unavailable. Attempting to reconnect in 5 seconds.
If problem persists, please contact your ACS administrator.
I have reloaded the appliance several times and the error persists.
ThibaultMean Wed, 07/21/2010 - 06:16
Hi there,
i thin kthe answer is in a previous post.
using the CLI, enter the following command:
show applicaion status acs
That should tell you wether all the services are running.
Anyway I fixed by reloading the box (which is not great).
Leo Bruni Wed, 07/21/2010 - 06:22
I have checked the application status and it states that all processes are running. This includes the database process. I also have now reloaded the box at least 10 times with no change.
michagar Sun, 07/25/2010 - 12:43
If all services are running, then it could be an issue that would need greater debugging from CLI.  If this is a new install that hasnt been moved into production yet, I would suggest re-imaging to the latest version of ACS (5.1 Patch level 3)
phamthanhchuong Thu, 07/29/2010 - 00:34
Can anyone send to me ACS 5.0  configuration document?? i don't know how to config acs 1120 appliance
Please, i need argent
Thanks for support
