FXO calls ATA but cant hear phone ring
Jul 21st, 2010
Hello All
The following is my setup and IOS VER
IOS (tm) MC3810 Software (MC3810-A2ISV5-M), Version 12.3(18), RELEASE SOFTWARE (fc3)
When I dial a number the pots receives the call and also forwards to num-exp. I see the light on the ata on port 1/6 lit and call stay up but
the called number does not ring at all.
Ohhh
This is how it flows
VOIP number dialed -----> Mc3810 (6 FXO ports) ------> ATA with gsm SIM card.-------XXX---- local GSM (PSTN) line
        BRoken here
Please some expert help me !
It worked for a while but I had power outage and lost all the setup (dont ask if backed up, I would be posting here)
I know the machine is still good
no cdp advertise-v2
voice-port 1/1
voice-port 1/2
voice-port 1/3
voice-port 1/4
voice-port 1/5
voice-port 1/6
dial-peer cor custom
dial-peer voice 2000 voip
description HOMELINE
shutdown
destination-pattern .
progress_ind setup enable 3
session protocol sipv2
session target ipv4:xxx.xxx.xxx.xxx
dtmf-relay rtp-nte h245-signal h245-alphanumeric
no vad
dial-peer voice 100 pots
no digit-strip
port 1/6
num-exp 1.......... 254734011111
gateway
timer receive-rtcp 15
This is the "sh call hist vo br"
Telephony call-legs: 1
SIP call-legs: 1
H323 call-legs: 0
MGCP call-legs: 0
Total call-legs: 2
1319 : 17619750ms.29 +3960 +6290 pid:0 Answer 4049749210
dur 00:00:02 tx:113/18080 rx:53/8480 10  (normal call clearing (16))
IP 64.154.41.150:16192 rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw
1319 : 17619760ms.30 +3940 +6300 pid:100 Originate 254734011111
dur 00:00:02 tx:53/8480 rx:113/18080 10  (normal call clearing (16))
Telephony 1/6 (30) [1/6] tx:0/0/0ms g711ulaw noise:-84dBm acom:7dBm
Bimal Chudasama Thu, 07/22/2010 - 06:17
It works now after a strange struggle!!
I have added Direct-inward-dial after the no-digit strip and it worked , but if I put it before the no-digit-strip it doesnt work !!!!!
Hmmmmm strange situation with dial peer pots.
