07-21-2010 05:56 AM - edited 03-10-2019 05:16 PM
Since some time we are struggling to get database replication working.
On the primary server it is reporting the following on "Database Replication active.csv""
07/21/2010 | 14:22:58 | SZ0910 | WARNING | ACS 'SZ0920' not replied to replication request - possibly short timeout or dead |
07/21/2010 | 14:12:08 | SZ0910 | INFO | Outbound replication cycle starting... |
In CSMon.log following is logged:
CSMon 07/21/2010 14:12:11 A 1544 13760 Pausing the monitoring of CSAuth for duration 600
CSMon 07/21/2010 14:12:11 A 1544 11640 Pausing the monitoring of CSLog for duration -1
CSMon 07/21/2010 14:12:14 A 1544 13788 Pausing the monitoring of CSRadius for duration -1
CSMon 07/21/2010 14:12:18 A 0641 3248 CSAuth: Paused State 0 6 Event Detected Level:2 Message:Service CSAuth has been suspended for a configured function to proceed. Monitoring will suspend until the service is restarted
CSMon 07/21/2010 14:12:18 A 0641 3248 CSLog: Stopped State 0 6 Event Detected Level:2 Message:Service CSLog has been stopped or paused by the system. Monitoring will suspend until the service is restarted
CSMon 07/21/2010 14:12:18 A 0641 3248 CSRadius: Stopped State 0 3 Event Detected Level:2 Message:Service CSRadius has been stopped or paused by the system. Monitoring will suspend until the service is restarted
CSMon 07/21/2010 14:12:18 A 1544 7716 Pausing the monitoring of CSTacacs for duration -1
CSMon 07/21/2010 14:12:28 A 0904 3248 Analysis: Level 2 'Service CSAuth has been suspended for a configured function to proceed. Monitoring will suspend until the service is restarted. Service CSLog has been stopped or paused by the system. Monitoring will suspend until the service is restarted. Service CSRadius has been stopped or paused by the system. Monitoring will suspend until the service is restarted. '
CSMon 07/21/2010 14:12:33 E 0351 3248 Failed to log accounting packet to logger localCSLog
CSMon 07/21/2010 14:12:33 A 0641 3248 CSTacacs: Stopped State 0 2 Event Detected Level:2 Message:Service CSTacacs has been stopped or paused by the system. Monitoring will suspend until the service is restarted
CSMon 07/21/2010 14:12:43 A 0904 3248 Analysis: Level 2 'Service CSTacacs has been stopped or paused by the system. Monitoring will suspend until the service is restarted. '
CSMon 07/21/2010 14:12:48 E 0351 3248 Failed to log accounting packet to logger localCSLog
CSMon 07/21/2010 14:22:18 A 0641 3248 CSAuth: State 0 6 Event Detected Level:4 Message:Service pause timed out. Please check the timeout settings for Replication and Backup
I have followed this checklist: https://supportforums.cisco.com/docs/DOC-8795 to make sure configs are ok.
But still replication fails.
There is no firewall in between.
Both ACS servers running on MS Windows Server 2003, SP2.
Can anybody help me in the right direction what could be possible cause of this or where else I can look for logging for further troubleshooting?
Thanks in advance for your help.
07-22-2010 12:00 AM
07/21/2010 14:22:58 SZ0910 WARNING ACS 'SZ0920' not replied to replication request - possibly short timeout or dead 07/21/2010 14:12:08 SZ0910 INFO Outbound replication cycle starting... In CSMon.log following is logged:
CSMon 07/21/2010 14:22:18 A 0641 3248 CSAuth: State 0 6 Event Detected Level:4 Message:Service pause timed out. Please check the timeout settings for Replication and Backup-------------------------------------------------------------------------------------------------------------------------------
Also check the port number TCP 2000 this is the replication port which needs to be opened between the primary and secondary ACS.
Hope to Help !!
Ganesh.H
07-22-2010 05:20 AM
Both ACS servers are listening to TCP port 2000:
Active Connections
Proto Local Address Foreign Address State
TCP SZ0910:49 SZ0910.szdelta.intern:0 LISTENING
TCP SZ0910:epmap SZ0910.szdelta.intern:0 LISTENING
TCP SZ0910:microsoft-ds SZ0910.szdelta.intern:0 LISTENING
TCP SZ0910:1039 SZ0910.szdelta.intern:0 LISTENING
TCP SZ0910:1200 SZ0910.szdelta.intern:0 LISTENING
TCP SZ0910:1311 SZ0910.szdelta.intern:0 LISTENING
TCP SZ0910:2000 SZ0910.szdelta.intern:0 LISTENING
TCP SZ0910:2001 SZ0910.szdelta.intern:0 LISTENING
TCP SZ0910:2002 SZ0910.szdelta.intern:0 LISTENING
TCP SZ0910:2868 SZ0910.szdelta.intern:0 LISTENING
TCP SZ0910:ms-wbt-server SZ0910.szdelta.intern:0 LISTENING
TCP SZ0910:3999 SZ0910.szdelta.intern:0 LISTENING
TCP SZ0910:47001 SZ0910.szdelta.intern:0 LISTENING
TCP SZ0910:netbios-ssn SZ0910.szdelta.intern:0 LISTENING
Active Connections
TCP sz0920:49 sz0920.szdelta.intern:0 LISTENING
TCP sz0920:epmap sz0920.szdelta.intern:0 LISTENING
TCP sz0920:microsoft-ds sz0920.szdelta.intern:0 LISTENING
TCP sz0920:1049 sz0920.szdelta.intern:0 LISTENING
TCP sz0920:1311 sz0920.szdelta.intern:0 LISTENING
TCP sz0920:2000 sz0920.szdelta.intern:0 LISTENING
TCP sz0920:2001 sz0920.szdelta.intern:0 LISTENING
TCP sz0920:2002 sz0920.szdelta.intern:0 LISTENING
TCP sz0920:2868 sz0920.szdelta.intern:0 LISTENING
TCP sz0920:ms-wbt-server sz0920.szdelta.intern:0 LISTENING
TCP sz0920:3483 sz0920.szdelta.intern:0 LISTENING
TCP sz0920:3999 sz0920.szdelta.intern:0 LISTENING
TCP sz0920:47001 sz0920.szdelta.intern:0 LISTENING
TCP sz0920:netbios-ssn sz0920.szdelta.intern:0 LISTENING
The server with name sz0920 is secondary and sz0910 is the primary which starts the replication.
