anitachoi3 Wed, 07/21/2010 - 07:39
Dear Brandon,
Where do I check the candiate's cert after I login to the system? Attached please find the screen dump for your advice.
rdgs
anitachoi3 Wed, 07/21/2010 - 09:24
Dear Brandon,
It displays following after I input the 16 digit numbers
"This site only validates the authenticity of the certificate issued to the individual named above. To validate if the individual's certification status is active please go to Cisco Certification Validation page. You will need a different validation id from the individual granting permission for you to view his/her active certifications. For more information how to use this feature please refer to the Tracking System User's guide"
How do I verify the cert status to be active or expired?
rdgs
Brandon Buffin Wed, 07/21/2010 - 09:29
  • Purple, 4500 points or more
The individual holding the certification will need to login to the Certification Tracking System and click Publish Credentials. They can then send their certification status to your email address.
Brandon
