ACS 5.1 Radius device administration error 11033
Jul 21st, 2010
I'm trying to configure ACS 5.1 as radius server for a catalyst switch but i can't make it work.
I keep on getting the "11033 Selected Service type is not Network Access" error message.
Tacacs works fine but radius does not.
Does anybody have a sample device administration config to use with RADIUS?
It seem the service type does not work with radius in this scenario ( radius + device admin).
Thibault.
Overall Rating: 1 (1 ratings)
Javier Henderson Thu, 07/22/2010 - 09:34
  • Cisco Employee,
The default access policy for RADIUS on ACS 5.1 is for network access, and you are trying to authenticate an interactice login. You need to create a new access policy, using RADIUS, and choose the correct login type.
ThibaultMean Fri, 07/23/2010 - 00:04
I am not using the default policy. I've created a new policy for device administration and Radius but each time I try to log into my switch I get this
11033 error message that basically tells me Radius is for network access not device administration.
...Hence my other post : is it possible to do RADIUS AAA for device admin with ACS 5.1?
So far I can't make it work and the report output is not verbose enough to tell the exact cause of this issue.
Thibault.
ThibaultMean Mon, 07/26/2010 - 00:53
Does anybody out there use ACS 5.1 with RADIUS for device administration?
Upenyu333_2 Tue, 09/14/2010 - 18:10
Hey,
Please use TACACS for device admin and RADIUS for network access and make sure the config on the switch is pointing to the correct radius server host
eg
radius-server host x.x.x.x auth-port 1812 acct-port 1813
Thats how I set-up my ACS5.1 and its working fine. I don't think you will be able to use RADIUS for device admin. Hope this helps
ThibaultMean Wed, 09/15/2010 - 00:59
Thanks for your help.
I'm still trying to find a way to configure ACS with RADIUS for device management.
Thibault.
ThibaultMean Mon, 09/20/2010 - 01:26
I've reinstalled ACS 5.0 from scratch on a VM (demo version) and it is now working fine.
Not sure about what exactly happened in the first place...
It's just a bit annoying that a fresh install or a server reboot are sometimes the only fix to a major issue.
I hope it is different with a real appliance.
ajay pandey Mon, 12/31/2012 - 01:34
Hello ibault,
I am also configuring ACS 5,3 for configuring some aaa clients switches to add as clinets for device management using radius.
can you give some hints to me ?
Ajay
Peter Koltl Mon, 12/31/2012 - 09:39
  • Silver, 250 points or more
  • Community Spotlight Award,
    Member's Choice, March 2016
For CLI login, the Service-Type attribute must be set to Login on the RADIUS server.
ajay pandey Tue, 01/01/2013 - 21:57
Could someone let me know how I can use same aaa client for using as 802.1x authentication server & also to work as a proxy radius for device administration ?
Means :
for 802.1x network access of user  : ACS will work as authentication server
for Device management : ACS will work as proxy and send the request to ACS server.
johnnylingo Tue, 04/16/2013 - 14:44
  • Bronze, 100 points or more
I don't understand what you mean by "ACS will work as a proxy and send the request to an ACS server".
Why would you want to proxy a request, just to send it to itself?
mateja.jovanovic Fri, 11/29/2013 - 06:33
Yeah, I also had this issue... It´s actually pretty easy to solve!
For ‘Administration of device via radIus’ you need to use Network Access service.
Go to
Access Policies > ... > Access  Services > Service Selection Rules
Check your RADIUS rule. You should have Network Access as the Service Type. Note that this cannot be modified, so delete the existing rule and create a new one with the same Identity and Authorization config.
Thats it, works as a charm
Related Content
