How can I get the PGW Serial Number?
Answered Question
Jul 21st, 2010
I´m trying to get the Serial Number of PGW in order to register it at cisco contract, but I don´t know how can I get it,  Can you give to me the way physically or by commands I can get that Number?
Correct Answer by scpage about 6 years 8 months ago
Not at this time.  The serial number is that of the SUN hardware, and there is not a standard interface for obtaining the that info across all servers.
Overall Rating: 5 (2 ratings)
Jeimy Galindo Mon, 07/26/2010 - 06:59
thanks for your quick answer, but Just for confirm, do you know how can I get the S/N using some kind of commands into the PGW software?
Correct Answer
scpage Mon, 07/26/2010 - 08:31
  • Cisco Employee,
Zhiping Cai Thu, 07/29/2010 - 19:05
  • Cisco Employee,
Maybe this link will help.
http://www.sunsolarisadmin.com/hardware/find-chasis-serial-number-using-sneep/
However, some of the Sun machines won't recognize the Serial number automatically. It needs to set it at the first time.
The command is:
# sneep -s
Then it will write into several places, include the eeprom.
After that you can get SN via sneep.
HTH.
abrajan Fri, 12/16/2011 - 07:21
run this command on the root prompt of your sun machine and you can get the suns Chassis Serial Number at the end of the file.
#prtdiag -v
Cheers,
Aby
